07-14-2014 04:14 AM - edited 03-04-2019 11:20 PM
Hi All ,
I have BGP running in my network . I have configured redistribute static . Due to this all the static routes are getting redistributed and advertised to BGP peer . Now if in case I do not want to advertised any particular static route to BGP peer . Is it possible to achieve this .
Below is the configuration :
router bgp 64508
bgp log-neighbor-changes
neighbor 10.0.47.22 remote-as 65000
neighbor 10.0.47.22 description " Connect to TATA 4 MB Link ID - 22064093"
neighbor 10.227.19.6 remote-as 18101
neighbor 10.227.19.6 description "RELIANCE 6MB LINK"
neighbor 172.22.8.230 remote-as 9829
neighbor 172.22.8.230 description "Connected to BSNL MPLS"
neighbor 192.168.200.34 remote-as 64505
neighbor 192.168.200.130 remote-as 64505
neighbor 192.168.200.210 remote-as 64505
neighbor 192.168.200.210 description ## FSS_ROUTER ##
neighbor 192.168.201.82 remote-as 64505
neighbor 192.168.201.82 description ## KAUSA_MUMBRA ##
neighbor 192.168.252.58 remote-as 64505
neighbor 192.168.252.58 description "Connected Kurla-1 Router"
address-family ipv4
redistribute connected
redistribute static
neighbor 10.0.47.22 activate
neighbor 10.0.47.22 allowas-in
neighbor 10.0.47.22 soft-reconfiguration inbound
neighbor 10.0.47.22 route-map TATA_IN_BLOCK in
neighbor 10.0.47.22 route-map TATA_block out
neighbor 10.227.19.6 activate
neighbor 10.227.19.6 soft-reconfiguration inbound
neighbor 10.227.19.6 route-map RCOM_block in
neighbor 172.22.8.230 activate
neighbor 172.22.8.230 allowas-in
neighbor 172.22.8.230 soft-reconfiguration inbound
neighbor 172.22.8.230 route-map SIFY_LOOPBACK out
neighbor 192.168.200.34 activate
neighbor 192.168.200.34 allowas-in
neighbor 192.168.200.34 soft-reconfiguration inbound
neighbor 192.168.200.130 activate
neighbor 192.168.200.130 allowas-in
neighbor 192.168.200.130 soft-reconfiguration inbound
neighbor 192.168.200.210 activate
neighbor 192.168.200.210 allowas-in
neighbor 192.168.200.210 soft-reconfiguration inbound
neighbor 192.168.201.82 activate
neighbor 192.168.201.82 allowas-in
neighbor 192.168.201.82 soft-reconfiguration inbound
neighbor 192.168.252.58 activate
neighbor 192.168.252.58 allowas-in
neighbor 192.168.252.58 soft-reconfiguration inbound
no auto-summary
no synchronization
network 192.168.100.0 mask 255.255.255.128
network 192.168.130.0
exit-address-family
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.252.33
ip route 10.120.35.0 255.255.255.192 172.22.8.230
ip route 10.150.101.0 255.255.255.0 192.168.200.210
ip route 10.254.254.0 255.255.255.0 192.168.200.210
ip route 172.22.11.144 255.255.255.252 172.22.8.230
ip route 172.22.101.16 255.255.255.252 172.22.8.230
ip route 172.23.97.36 255.255.255.252 172.22.8.230
ip route 172.23.97.44 255.255.255.252 172.22.8.230
ip route 172.25.1.64 255.255.255.252 172.22.8.230
ip route 172.25.33.68 255.255.255.252 172.22.8.230
ip route 172.25.48.132 255.255.255.252 172.22.8.230
ip route 172.25.66.0 255.255.255.252 172.22.8.230
ip route 172.25.96.64 255.255.255.252 172.22.8.230
ip route 172.25.96.252 255.255.255.252 172.22.8.230
ip route 172.25.97.44 255.255.255.252 172.22.8.230
ip route 172.25.97.100 255.255.255.252 172.22.8.230
ip route 172.25.97.232 255.255.255.252 172.22.8.230
ip route 172.31.200.0 255.255.255.0 10.0.47.22
ip route 192.168.8.0 255.255.255.0 10.0.47.22
ip route 192.168.20.0 255.255.255.0 10.0.47.22
ip route 192.168.48.0 255.255.255.224 10.227.19.6
ip route 192.168.101.1 255.255.255.255 192.168.250.2 <=== This route I do not want to advertise to BGP peer
ip route 192.168.76.0 255.255.255.0 172.22.8.230
ip route 192.168.81.232 255.255.255.248 192.168.252.33
ip route 192.168.82.0 255.255.255.0 172.22.8.230
ip route 192.168.87.0 255.255.255.0 10.227.19.6
ip route 192.168.88.0 255.255.255.224 10.227.19.6
ip route 192.168.96.160 255.255.255.224 172.22.8.230
ip route 192.168.97.160 255.255.255.224 10.227.19.6
ip route 192.168.98.128 255.255.255.224 172.22.8.230
ip route 192.186.46.0 255.255.255.0 172.22.8.230
Kindly revert .
Solved! Go to Solution.
07-14-2014 05:10 AM
Hi Tusharp,
It can be done by using route map with route tagging
address-family ipv4
redistribute static route-map NO_DISTRIBUTE
ip route 192.168.101.1 255.255.255.255 192.168.250.2 tag 2
route-map NO_DISTRIBUTE deny 10
match tag 2
route-map NO_DISTRIBUTE permit 20
kazim
"If post helpful don't forget to select correct answer and rating"
07-14-2014 05:10 AM
Hi Tusharp,
address-family ipv4
match tag 2
kazim
