find: /bootflash/: Input/output error
JasonT1000
Hello -
I need help with this error on my router. I haven't try to reboot it yet but I'm just wondering what might have caused this error. From the Internet forum, it seems like a hardware issue. What can I do to determine the root cause? Do I have an option to fix it without rebooting the router? Thanks in advance.
show bootflash:
-#- --length-- ---------date/time--------- path
1 4096 Sep 18 2019 20:49:51 +00:00 /bootflash/
6264422400 bytes available (487481344 bytes used)
8 Replies 8
Mark Elsen
 - Seems worry some could you try dir bootflash: and check if that works ?
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Nothing is in here too.
#dir bootflash:
Directory of bootflash:/
No files in directory
7113240576 bytes total (6264422400 bytes free)
Post the complete output to the command "sh version".
show version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
router1 uptime is 16 weeks, 1 day, 14 hours, 1 minute
Uptime for this control processor is 16 weeks, 1 day, 14 hours, 3 minutes
System returned to ROM by reload at 06:00:20 UTC Thu Aug 3 2017
System restarted at 13:51:55 CDT Sat Jun 1 2019
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Upgrade the firmware of the router.
The appliance is running a re-build version.
Leo Laohoo
Post the complete output to the command "dir all".
Nothing is in there. Here is the complete result.
#dir /all
 - Since this might indicate a 'strong problem' with your router I would first of all save the current running config to a destination outside the router. Then issue fsck bootflash:    Then and in the end you will have to test whether this device can still survive a reboot, and reboot it (possible during a none-production period and or having a standby device in place , for instance).
 M.
       Beauty and terror
      Just keep going
       No feeling is final
