firepower
Hi specialists,
  1. When starting-up firepower & face to "locally config", what will occur if I choose "Yes"?
  2. Policies-->Network discovery-->Networks-->Add rule   What's the difference between "host" & "user"?
  3. What does "generate event" do with a signature?        policies-->access control-->intrusion
  4. Does it support PAT?
6 Replies 6
balaji.bandi
BB - this means you need to have FDM to manage firepower.
BB -
user input data—Data added through the Firepower System user interface. You can modify a host’s operating system or application identity through this interface.
host import input data—Data imported using a command line utility.
more information can be find here :
https://www.cisco.com/c/en/us/td/docs/security/firepower/601/configuration/guide/fpmc-config-guide-v601/Introduction_to_Network_Discovery.html#ID-2221-000001f4
BB - If any of the policy matches, it generates for review or co-relation
https://www.cisco.com/c/en/us/td/docs/security/firepower/60/configuration/guide/fpmc-config-guide-v60/Getting_Started_with_Intrusion_Policies.html
BB- yes it does
configuration for reference :
https://www.cisco.com/c/en/us/support/docs/security/firepower-management-center/212702-configure-and-verify-nat-on-ftd.html
BB
Thanks sir for replying all my questions spectacularly.
What does Network Discovery do?
How long is Firepower's recommendation for Network Discovery?  Shall I remove Network discovery after it finished its duty?
What's the difference between signature & policy in NGIPS?
have you got time to read the document which i was suggested on other post ?
Most of the below questions already answereed : (let me answer in short)
BB- discover your network devices
BB - 10min to few days or months - depends on network size  and what you like to discover in the network
BB -  Thread will help you
BB
Thanks sir for your great replies, actually, I had a look to your documents but you're right I'll read them in-depth. By the way, do u live in US?
Sure you need to read more documents to understand, so some time we over look.
BB
Hi again, I'm studying document about NAT u sent me earlier. I faced these expressions "interface group", "LINA CLI" What do them mean? Which Firepower ver is it? & What Firepower version is standard in today's market?
What does "translate hits" mean in "show nat"? show cap CAPI, show cap CAPO?
Thanks again
