firewall between directly connected networks
hi everyone,
i have a switch (2960) which is configured with several virtual interfaces. i need to add routing ability to this switch. however when i enable routing, the switch sees all the interfaces i created as being directly connected. but i also need to have the traffic inspected as it enters any of the interfaces. i have an asa and i would like the switch to forward all the traffic to this asa where it gets inspected. is it possible to do this?
thanks
Richard Burts
If you were to do the routing between subnets on your ASA and leave the switch as layer 2 then the ASA could inspect all the traffic. If you enable routing on the 2960 then I am not aware of a way to send all traffic to the ASA to be inspected.
Rick
Rick
thank you Richard.
trfinkenstadt
Can you put the default gateway for your vlans onto the ASA, remove the SVIs on the 2960, and route through the ASA?
i will give it a try. thanks.
