firewall
ckyenze07
am changing my internet connection to another isp .the former is using serial interface to connect wan and the latter is using 2 ethernet cables.
have changed the ips fromthe router and firewall but i cannot browse .my pix type is 515e .please help
dongdongliu
hi,
1st, make sure you can ping new ISP`s GW address successfully from router or firewall.
2nd, to check out NAT if LAN was using private address or to ask ISP whether your address block has been advertised if you have got a new public address block.
regards
dongdong
Danilo Dy
DNS and clear xlate
