Flash memory upgrade!
paltel
Is there is any restriction about Flash memory upgrade for Cisco 3660 and 3640 routers, i have 2 3660 and 2 3640(with 32 MB SIMM flash memory for each, except for the last one 3640 with 8 MB Flash memory) and i want to buy PCMCIA Flash memory 32MB for each one. Is there is any restriction about the max Flash memory in MB that to upgrade, and i think that PCMCIA flash memory size must be small than or equal the SIMM flash memory. right?
15 Replies 15
there is no relation or dependency between the flash SIMM size and the PCMCIA flash size. You can install a maximum of 2x16=32MB of external PCMCIA flash.
Is that the information you are looking for ?
GP
Yes, it means that i can install up to 64MB Flash memory for both Cisco 3660 and Cisco 3640 routers. i.e i need to buy 2 PCMCIA flash memory 16 MB for each router. right? Or i can get 2 PCMCIA flash memory with 32MB for each router to have 96 MB flash memory(32 SIMM plus 2 external PCMCIA with 32 MB).
there is a slight difference between the 3640 and the 3660 regarding the maximum flash size: the 3640 supports a maximum of 32MB SIMM flash, while the 3660 supports 64MB. So, on the 3640, you can achieve a maximum of 64MB, while on the 3660, that maximum is 96MB.
You might want to check the data sheets below, they list the memory configurations possible on the various platforms:
Cisco 3600 Series Multifunction Platforms (3620 and 3640/3640A)
Data Sheet
http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_data_sheet09186a0080091f6f.html
Cisco 3660 Multiservice Platform
Data Sheet
http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_data_sheet09186a0080091ba4.html
HTH,
GP
Thanks alot.. I would like to ask about the flash memory SIMM, both Cisco 3640 and 3660 contain 2 slots Flash memory. for example, if you have 32 MB SIMM flash memory how can we determine if this 32 MB occupied one slot(32 MB SIMM flash memory) or 2*16 ?
Another thing, can we use the replaced 32 or 16 MB DRAM from 3660 to 3640? i think no because two different access time and pin numbers. just to ensure that.
Thanks again
for the 3640, there is a procedure to determine which slots are occupied, check this link:
How to Determine the SIMM Configuration of a Cisco 3620 or 3640 Series Router
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a0080104555.shtml
Not sure if there is something similar for the 3660...
Regarding the memory: I think the 32MB SIMMs for the 3660 are not compatible with the 3640, but the 16MB SIMMs are. Check this link for the part numbers:
Cisco 3000 Series Router Memory
http://www.memoryx.net/3000router.html
GP
Hi Mr. gpauwen ,
Thank you for your immediate reply. I know that document which give you how many memory exist at each bank for the memory. I want to ask about Flash memory. For both 3640 and 3660 each contain 2 SIMM flash memory, i want to test this 2 slots.
Thank you
Cisco routers 3640 and 3660 have 2 sots for Flash memory.Can we determine the size of SIMM flash memory exist at each slot? for example, i f we have 32 MB flash memory (SIMM). i need to know is this 32MB at one slot or at the two slots??
Thank you
On my 2650XM, I know that I have 48 MB Flash memory.
Try issuing "sh flash chips"
This is what I get on my router.
49152K bytes of processor board System flash (Read/Write)
Chip Bank Code Size Name
1 1 8917 8192KB INTEL 28F640J3
2 1 8917 8192KB INTEL 28F640J3
1 2 8918 16384KB INTEL 28F128J3
2 2 8918 16384KB INTEL 28F128J3
As you can see bank1 (onboard) has 2 chips of 8MB each, and bank2 has 2 chips of each 16MB. For a total of 48MB.
Is this what you wan't to know.
I issue this command before at my Cisco 3660 router and this is what i get:
PALTEL#sh flash: chips
32768K bytes of processor board System flash (Read/Write)
1 1 01AD 2048KB AMD 29F016
2 1 01AD 2048KB AMD 29F016
3 1 01AD 2048KB AMD 29F016
4 1 01AD 2048KB AMD 29F016
1 2 01AD 2048KB AMD 29F016
2 2 01AD 2048KB AMD 29F016
3 2 01AD 2048KB AMD 29F016
4 2 01AD 2048KB AMD 29F016
1 3 01AD 2048KB AMD 29F016
2 3 01AD 2048KB AMD 29F016
3 3 01AD 2048KB AMD 29F016
4 3 01AD 2048KB AMD 29F016
1 4 01AD 2048KB AMD 29F016
2 4 01AD 2048KB AMD 29F016
3 4 01AD 2048KB AMD 29F016
4 4 01AD 2048KB AMD 29F016
You see,i can't understand this info. 4 banks!!!
Hmm, you wright, this is confusing.
What does it say when doing "sh flash all"?
My 2600XM says "bank-size 16384K + 32768K".
2650XM-Router#sh flas all
Partition Size Used Free Bank-Size State Copy Mode
1 49151K 37849K 11302K 16384K Read/Write Direct
+ 32768K
How may banks do you have on the board, and how many PCMCIA slots do you have, I'm guessing 2 of each, correct?
Yes, correct!
And what did you get with a "sh flash all"?
PALTEL#sh flash: all
1 32767K 21068K 11699K 8192K Read/Write Direct
System flash directory:
File Length Name/status
addr fcksum ccksum
1 21573644 c3660-js-mz.123-10a.bin
0x40 0xD93C 0xD93C
[21573708 bytes used, 11980720 available, 33554428 total]
