FLEXWAN Module for ATM
safe
Dear all,
Is any one having documentation about how to design Flexwan module for ATM.My requirement is that now i hv one 6509 Switch which having FlexWaN module on which we will terminate STM in which we give Bandwidth to all customer thr' that Pipe only.We need to config different VLANs for each customer.How these VLANs find there own path.Is any one have sample documentation pls give me link.
STM-1 =======(6509 FLexWAN)----Different customers.
TIA
SAM
mheusinger
Level 10
Level 10
unfortunately I do not quite understand your requirements. Do you want normal IP routing of traffic from VLANs to the ATM interface and back with the ATM having one PVC?
Then normal IP routing on the Cat6509 should do the trick.
Or would you like to separate customer traffic from the VLAN over a separate PVC per customer? Then either PBR (policy based routing) matching IP addresses could be used. Another option would be to use Multi-VRF (aka VRF-lite) with a separate IP routing table per customer. Then each PVC should be cofigured on a separate subinterface and the ATM subint plus the VLAN interface should be assigned to the customer VRF.
Hope this helps! Pleast rate all posts.
Regards, Martin
