Forward iBGP VPNv4 routes from PE to VRF of CE
lukassgg
Good Morning,
We're having troubles redistributing routes learned over iBGP VPNv4 from a PE to the VRF Customer1 of a connected CE.
The PE (XR3) receives the IPv4 route 10.2.0.0/24 over iBGP VPNv4 from the RR (2011::1):
OS is Cisco IOS XR.
RP/0/RP0/CPU0:XR3#show bgp vpnv4 unicast neighbors 2011::1 routes
Fri Dec 2 08:27:45.456 UTC
BGP router identifier 3.3.3.3, local AS number 65000
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0 RD version: 0
BGP main routing table version 7321
BGP NSR Initial initsync version 2 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf Customer1)
*>i10.2.0.0/24 2015::1 100 0 64700 i
Processed 1 prefixes, 1 paths
But the PE (XR3) doesn't forward this route 10.2.0.0/24 to the VRF Customer1 of the, over eBGP connected, CE (10.36.0.2):
RP/0/RP0/CPU0:XR3#show bgp vrf Customer1 ipv4 unicast neighbors 10.36.0.2 advertised-routes
Fri Dec 2 08:31:35.239 UTC
RP/0/RP0/CPU0:XR3#
We're running dualstack (IPv4, IPv6) and the PE receives the IPv6 route fd00:a::/112 from our RR.
RP/0/RP0/CPU0:XR3#show bgp vpnv6 unicast neighbors 2011::1 routes
Fri Dec 2 08:55:51.047 UTC
BGP main routing table version 56
BGP NSR Initial initsync version 1 (Reached)
*>ifd00:a::/112 2015::1 100 0 64700 i
And also forwards this IPv6 route fd00:a::/112 to to VRF for our CE.
RP/0/RP0/CPU0:XR3#show bgp vrf Customer1 ipv6 unicast neighbors 2001:db8:36::6 advertised-routes
Fri Dec 2 08:57:15.310 UTC
Network Next Hop From AS Path
fd00:a::/112 2001:db8:36::3 2011::1 65000 64700i
So I'm assuming we're probably missing something in the BGP IPv4 unicast settings of our PE (XR3), that doesn't forward the route 10.2.0.0/24 to our VRF Customer1 of the CE.
This is our PE (XR3) BGP configuration:
RP/0/RP0/CPU0:XR3#show run | begin bgp
Fri Dec 2 08:39:03.632 UTC
Building configuration...
router bgp 65000
bgp router-id 3.3.3.3
address-family ipv4 unicast
address-family vpnv4 unicast
address-family ipv6 unicast
address-family vpnv6 unicast
segment-routing srv6
locator MAIN
neighbor 2011::1 (This is the Route Reflector)
remote-as 65000
update-source Loopback0
vrf Customer1
rd 1:1
alloc mode per-ce
neighbor 10.36.0.2 (This is our CE IPv4)
remote-as 64800
update-source GigabitEthernet0/0/0/4
route-policy pass in
route-policy pass out
next-hop-self
neighbor 2001:db8:36::6 (This is our CE IPv6)
remote-as 64800
next-hop-self
Thanks for any help in advance.
edit:
BGP IPv4 unicast- and BGP IPv6 unicast-peering is established between PE (XR3) and CE.
RP/0/RP0/CPU0:XR3#show bgp vrf Customer1 ipv4 unicast neighbors brief
Fri Dec 2 09:13:38.275 UTC
Neighbor Spk AS Description Up/Down NBRState
10.36.0.2 0 64800 1d18h Established
RP/0/RP0/CPU0:XR3#show bgp vrf Customer1 ipv6 unicast neighbors brief
Fri Dec 2 09:14:49.187 UTC
2001:db8:36::6 0 64800 1d18h Established
Global VRF Config on PE (XR3):
RP/0/RP0/CPU0:XR3#show run vrf
Fri Dec 2 09:21:42.584 UTC
vrf Customer1
import route-target
1:1
export route-target
1:1
import route-target
1:1
export route-target
1:1
Harold Ritter
Hi @lukassgg ,
You are missing a few configuration statements for VPNv4 to work properly. You have them configured for VPNv6 that is why the ipv6 routes are passed to the CE without a problem.
router bgp 65000
locator MAIN
vrf Customer1
rd 1:1
alloc mode per-ce
16 Replies 16
@Harold Ritter get the issue.
Harold Ritter
Hi @lukassgg ,
router bgp 65000
locator MAIN
vrf Customer1
rd 1:1
alloc mode per-ce
Hi @Harold Ritter ,
thank you very much for your response.
I implemented your changes, but unfortunately there are still no routes being advertised from PE (XR3) to the VRF of our CE.
Fri Dec 2 14:15:19.261 UTC
router bgp 65000
locator MAIN
locator MAIN
neighbor 2011::1
remote-as 65000
vrf Customer1
rd 1:1
alloc mode per-ce
alloc mode per-ce
neighbor 10.36.0.2
remote-as 64800
next-hop-self
remote-as 64800
next-hop-self
Fri Dec 2 14:19:12.968 UTC
RP/0/RP0/CPU0:XR3#
Looking forward to your response.
does BGP have active session to this neighbor ?
I see you use g0/0/4 as update source for both address family IPv4 and IPv6 ?
I @MHM Cisco World ,
Here's the output that was given in the original post, showing that both IPv6 and IPv4 neighbours are up.
If you mean the eBGP session between PE (XR3) and CE then yes.
Fri Dec 2 14:38:19.869 UTC
10.36.0.2 0 64800 2d00h Established
Yes, we use the same interface for IPv4- and IPv6-BGP peering.
We wanted both IPv4 and IPv6 peering between PE and CE.
you meaning G0/0/4 is dual stacking ?
Yes.
Hi @lukassgg ,
Can you post the output for the following commands:
sh bgp vpnv4 unicast vrf Customer1 10.2.0.0/24
sh bgp vrf Customer1 ipv4 uni 10.2.0.0/24
show route vrf Customer1 10.2.0.0/24
RP/0/RP0/CPU0:XR3#show bgp vpnv4 unicast vrf Customer1 10.2.0.0/24
Fri Dec 2 14:48:39.245 UTC
BGP routing table entry for 10.2.0.0/24, Route Distinguisher: 1:1
Versions:
Process bRIB/RIB SendTblVer
Speaker 387345 387345
Last Modified: Dec 2 14:48:07.458 for 00:00:31
Paths: (1 available, best #1)
Not advertised to any peer
Path #1: Received by speaker 0
64700
2015::1 (metric 10) from 2011::1 (5.5.5.5)
Received Label 24000
Origin IGP, localpref 100, valid, internal, best, group-best, import-candidate, imported
Received Path ID 0, Local Path ID 1, version 387345
Extended community: RT:1:1
Originator: 5.5.5.5, Cluster list: 1.1.1.1
Source AFI: VPNv4 Unicast, Source VRF: Customer1, Source Route Distinguisher: 1:1
Fri Dec 2 14:49:53.833 UTC
BGP VRF Customer1, state: Active
BGP Route Distinguisher: 1:1
VRF ID: 0x60000003
Table ID: 0xe0000003 RD version: 387345
BGP main routing table version 387345
r>i10.2.0.0/24 2015::1 100 0 64700 i
*> 10.6.0.1/32 10.36.0.2 0 0 64800 i
Processed 2 prefixes, 2 paths
RP/0/RP0/CPU0:XR3#show route vrf Customer1 10.2.0.0/24
Fri Dec 2 14:50:56.965 UTC
% Network not in table
Hi @lukassgg ,
10.2.0.0/24 has a RIB failure condition, but this route is not present in the RIB. What IOS-XR version are you running and on what platform?
Can you do a
clear bgp vpnv4 uni * soft in
and see if it clears the RIB failure condition?
r>i10.2.0.0/24 2015::1 100 0 64700 i <<--
@Harold Ritter  mention the route is rib failure, and I see Not advertised to any peer
which can cause of rib failure route.
the interesting point here the next-hop,
we talk about IPv4 but the next-hop is IPv6.
so I think the source of this issue is from the origin of this route.
Hi @lukassgg ,
Can you check the originating PE (5.5.5.5) to make sure that it is not missing the SRv6 configuration statements like XR3 did?
Hi @Harold Ritter
You're so right, I totally forgot about that.
I added the missing SRv6 configuration on the other PE called XR5 and it seems to work.
The PE (XR3) now advertises the network 10.2.0.0/24 to the CE1
Fri Dec 2 18:01:38.960 UTC
10.2.0.0/24 10.36.0.1 2011::1 65000 64700i
No RIB-failure message anymore.
And the route 10.2.0.0/24 is even visible on the CE1.
CE1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.123.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 192.168.123.1
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
B 10.2.0.0/24 [20/0] via 10.36.0.1, 00:29:07
C 10.6.0.1/32 is directly connected, Loopback0
C 10.36.0.0/30 is directly connected, GigabitEthernet2
L 10.36.0.2/32 is directly connected, GigabitEthernet2
192.168.123.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.123.0/24 is directly connected, GigabitEthernet1
L 192.168.123.173/32 is directly connected, GigabitEthernet1
Likewise the route to the network on CE1 10.6.0.1/32 is now also being advertised from the other PE (XR5) to the other CE device.
RP/0/RP0/CPU0:XR5#show bgp vrf Customer1 ipv4 unicast neighbors 10.101.10.10 advertised-routes
Fri Dec 2 18:06:00.014 UTC
10.6.0.1/32 10.101.10.5 2011::1 65000 64800i
Thank you so much
