505
Forwarding the public IP pool
Hello everyone.
I have a situation like this:
I have a pool of public addresses. x.x.98.126/30
the whole pool is used for different services and servers.
x.x.98.126 -I used for regular users.
the problem is that port forwarding is configured for the given IP (x.x.98.126) address not working.
eg x.x.98.133- everything works all forwards.
I also have VPN-anyconnect on x.x.98.126 - it also does not work.
but if I visit myip.com here it shows me that I have x.x.98.126.
strange what's going on.
who can help fix and suggest what happened?
1 ACCEPTED SOLUTION
basically, what you need to do is create the 'pat-pool' object that your NAT statements are referring to:
nat (INSIDELINK,outside) source dynamic X.X.0.0 pat-pool interface
nat (INSIDELINK,outside) source dynamic inside_network pat-pool interface
nat (INSIDELINK,outside) source dynamic X.X.100.0 pat-pool interface
nat (INSIDELINK,outside) source dynamic X.X.101.0 pat-pool interface
nat (INSIDELINK,outside) source dynamic X.X.102.0 pat-pool interface
This object is not in your configuration, add it:
object network pat-pool
range x.x.98.127 x.x.98.132
13 REPLIES 13
Georg Pauwen
VIP Expert
--> I have a pool of public addresses. x.x.98.126/30
If that is your address pool, only addresses x.x.98.127 and x.x.98.128 would be available. Can you clarify ?
balaji.bandi
VIP Master
If you are using this IP ( (x.x.98.126) )for NAT going outside network for you LAN, then we may need to understand configuration before we suggest something here so please do post the full configuration to undertand.
Rest other IP address working because there no issue with that IP since it as not used.
BB
How to Ask The Community for Help
HI balaji.bandi
I have put some screenshots. if this is not enough, you can tell what kind of information to provide you. I'll post it all.
since you are using FMC, I assume you are trying to configure either an ASA or a Firepower device ? Either of those has a CLI and the 'sh run' command, post the output of that...
Dear Georg Pauwen.
sh run in the attachment. sorry but I hid IP addresses
I cannot find the network object 'pat-pool' anywhere in your configuration ? You are referring to that object in several NAT statements, make sure it is actually defined..
Thank you for your prompt reply.
Forgive me, I'm not a high-level specialist. You probably already guessed it.
Do I need to do this?
Hello
I would be careful then as this looks like it a production FW and as such if you dont know what your are doing then you could cause an outage - Document any changes you make so you can at least backout if need be, if something you apply doesn't work then don't leave it and try and add another avenue remove that last change and then proceed.
Make sure you have a change window for any changes so at least your covered if the worst happens.
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
all of the (dynamic, since there are no static) NAT translations that go out the 'outside' interface, as well as the VPN, are referring to a non-existing network object named 'pat-pool'. That means nothing that uses your x.x.98.126 address will work. You need to create the network object and put whatever you need in there.
ERROR
paul driver
VIP Mentor
Hello
Hello everyone.
Doesn't make sense those two highlighted addresses are in deferent subnenetworks?
What single ip address are you using i assume its x.x.98.126/30 for all egress traffic even specific port address translation?
kind regards
Paul
Thanks to all. it was a weekend and there was no access to equipment. today I will continue to understand, taking into account all the recommendations above.
I just do not understand what exactly I need to do. Can anyone advise what exactly I should try to do?
