FPGA
enriquebs
HI all,
We need to upgrade the fpga version on a 7314 box but we've doubt, the thing is that a route processor (after the upgrade) will have a different version than the other, as you can see in the following output:
PE01#sh c7300
Slot Card Type Status Insertion time
0,1 NSE100 (Active) Up 3w0d ago
2,3 NSE100 (Standby) Up 3w0d ago
4 1PA Carrier Card Active 3w0d ago
FPGA information:
Hardware FPGA version
Slot Card Type Version Bundled Flash Current
*0 NSE100 (MB) 05.01 01.14 01.08 01.08
0 NSE100 (DB) 05.01 01.08 01.08 01.08
4 1PA Carrier Card 02.00 01.40 01.40 01.40
* - Card needs an FPGA update
# - Card needs to be reloaded for the new FPGA to take effect
Port Adapter Information
Slot PA Type Status Insertion time
4 PA-A3-OC3SMI Active 3w0d ago
System is compliant with hardware configuration guidelines.
Network IO Interrupt Throttling:
throttle count=671, timer count=671
active=0, configured=1
netint usec=4000, netint mask usec=200
Anyone have idea wheter or not it'll be an issue?
THX
smahbub
Level 6
Level 6
Try Cost out as before using max metric LSA command
