Frame-relay interface not coming up!
ashrafkhanm
Hello Everyone,
I 'm trying to set up a home lab with a couple of 28XX and 2651XM series routers.
I would like to simulate a frame-relay connection between HQ, Branch1 and Branch2 . All of them are conneced to a PSTN switch (2811 router) via T1 cross over cables. The connectivity is like this.
        HQ
                                                               Branch 1 ---> PSTN-WAN <--  Branch 2
I have configured all the routers and FR switch with necessary configuration. However the link between HQ and Branch1 is not coming up. On both the routers I could see the line protocol is down.I have pasted the configuration below. Please advise if am missing anything here. (It is not a cable/port issue)
From the  PSTN-WAN router
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24
description ** SERIAL DATA CONNECTION TO HQ-RTR **
controller T1 0/1/0
framing esf
linecode b8zs
description ** SERIAL DATA CONNECTION TO BR1-RTR **
interface Serial0/0/0:0
description ** T1 DATA CONNECTION TO HQ-RTR **
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 201 interface Serial0/1/0:0 101
frame-relay route 202 interface Serial0/3/0:0 102
description ** T1 DATA CONNECTION TO BR1-RTR **
no ip address
PSTN-WAN#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.10.100.2     YES NVRAM  up                    up
FastEthernet0/1            192.168.0.11    YES NVRAM  up                    up
Serial0/0/0:0              unassigned      YES NVRAM  up                    up
Serial0/0/1:0              unassigned      YES unset  down                  down
Serial0/0/1:1              unassigned      YES unset  down                  down
Serial0/0/1:2              unassigned      YES unset  down                  down
Serial0/0/1:22             unassigned      YES unset  down                  down
Serial0/0/1:23             unassigned      YES NVRAM  up                    up
Serial0/1/0:0              unassigned      YES manual up                    down
Serial0/1/1:0              unassigned      YES unset  down                  down
Serial0/1/1:1              unassigned      YES unset  down                  down
Serial0/1/1:2              unassigned      YES unset  down                  down
Serial0/1/1:22             unassigned      YES unset  down                  down
Serial0/1/1:23             unassigned      YES NVRAM  up                    up
Serial0/3/0:0              unassigned      YES NVRAM  up                    up
Serial0/3/1:0              unassigned      YES unset  down                  down
Serial0/3/1:1              unassigned      YES unset  down                  down
Serial0/3/1:2              unassigned      YES unset  down                  down
Serial0/3/1:22             unassigned      YES unset  down                  down
Serial0/3/1:23             unassigned      YES NVRAM  up                    up
Loopback0                  1.1.1.1         YES NVRAM  up                    up
From the HQ router
controller T1 0/0/0
framing esf
linecode b8zs
no ip address
interface Serial0/0/0:0.1 point-to-point
ip address 10.10.111.1 255.255.255.0
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 201
interface Serial0/0/0:0.2 point-to-point
ip address 10.10.112.1 255.255.255.0
ip ospf mtu-ignore
frame-relay interface-dlci 202
From the BR1 router
controller T1 1/0
framing esf
linecode b8zs
interface Serial 1/0:0
no ip address
fair-queue
interface Serial 1/0:0.1 point-to-point
ip address 10.10.111.2 255.255.255.0
ip ospf mtu-ignore
frame-relay interface-dlci 101
there is no frame route statement here but it should
2) HQ frame-relay interface has Cisco encapsulation but BR1 has got IETF so it won't work.
Regards.
Alain
Reza Sharifi
Can you clock the DCE side and test again?
clock rate xx
http://www.cisco.com/en/US/docs/ios/12_0/dial/configuration/guide/dcsyncs.html
Reza,
I tried it...But no luck..
Regards.
Alain
Sorry for the late reply Alain...Yes it worked after I made both HQ and BR1 frame relay interfaces as IETF.
Thank you very much for your help !!!!!
Ashraf
