Frame Relay latency
mselim2000
Level 5
Level 5
I have two serial interfaces terminated at Frame Relay switch. I am reciving large latency when I try t ping using larg packet size. does anyone know why
I am using extend ping and 1200 for P size
peterledwidge
Are you experiencing congestion on the links?
peterledwidge
You can adjust the load interval from the default 5 minute value
to say 30 seconds, so you have a more real time view of load on the
interface.
Router(config)#int sx
Router(config-if)#load-interval 30
Router(config-if)#^Z
Once you've finished you can set it back to the 5 minute value.
Router(config-if)#load-interval 300
Peter
CCampbell_2
What IOS are you running and are you using LFI on this link? I believe there was a bug related to large packets, high latency and LFI.
