Frame Relay Multipoint - Does FR MP support broadcast?
Juan Urti
Hi all! i´m studing my CCIE Lab exam, and i want to know if does FR Multipoint Support broadcast?
If the answer is yes, how does it do?
Many Thanks!!!!
Reza Sharifi
Not by default, but there is broadcast keyword you can use:
Have a look a this doc:
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml#broadcastkey
Hi thanks!!! i had readed some documents, and i saw that FR doesn´t support technically broadcast.
A router with broadcast keyword in the frame-relay map ip command, will repeat every "broadcast" packet in every DLCI, to ensure that the broadcast (routing protocol) reaches every neighbor.
https://learningnetwork.cisco.com/thread/36841
Are you agree with me?
Thanks!!!
Juan
Thats why they call this type of network NBMA "non-broadcast multi-access"
