Frame Relay on NBMA
abhijit379
I am trying to simulate a Frame Relay topology on a NBMA network.
I am posting the details of sh Running config, sh Frame-relay Map, sh ip int brief, show ip route and ping result of all three routers. Could any one please give me any idea, why East router cant ping west router. Show ip route is showing all the routes properly.
HQ#show running-config
Building configuration...
Current configuration : 1122 bytes
version 12.3
hostname HQ
boot-start-marker
boot-end-marker
memory-size iomem 15
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback1
ip address 10.1.1.1 255.255.255.0
interface Loopback2
ip address 10.1.2.1 255.255.255.0
interface Loopback3
ip address 10.1.3.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
interface Serial0/0.1 multipoint
ip address 172.16.124.1 255.255.255.248
no ip split-horizon eigrp 25
frame-relay map ip 172.16.124.2 102 broadcast
frame-relay map ip 172.16.124.3 103 broadcast
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.1.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
no ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
HQ#show frame-relay map
Serial0/0.1 (up): ip 172.16.124.2 dlci 102(0x66,0x1860), static,
              broadcast,
              CISCO, status defined, active
Serial0/0.1 (up): ip 172.16.124.3 dlci 103(0x67,0x1870), static,
              broadcast,
HQ#show ip int brief
Interface                      IP-Address        OK?  Method  Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM    administratively down down
Serial0/0                       unassigned      YES NVRAM    up                    up
Serial0/0.1                    172.16.124.1    YES NVRAM    up                    up
FastEthernet0/1            unassigned      YES NVRAM    administratively down down
Serial0/1                       unassigned      YES NVRAM    administratively down down
Loopback1                    10.1.1.1          YES NVRAM    up                    up
Loopback2                    10.1.2.1          YES NVRAM    up                    up
Loopback3                    10.1.3.1          YES NVRAM    up                    up
HQ#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.16.0.0/29 is subnetted, 1 subnets
C       172.16.124.0 is directly connected, Serial0/0.1
     10.0.0.0/24 is subnetted, 9 subnets
D       10.3.1.0 [90/2297856] via 172.16.124.3, 00:08:37, Serial0/0.1
C       10.1.3.0 is directly connected, Loopback3
D       10.2.1.0 [90/2297856] via 172.16.124.2, 00:08:37, Serial0/0.1
C       10.1.2.0 is directly connected, Loopback2
D       10.3.3.0 [90/2297856] via 172.16.124.3, 00:08:37, Serial0/0.1
D       10.2.2.0 [90/2297856] via 172.16.124.2, 00:08:37, Serial0/0.1
C       10.1.1.0 is directly connected, Loopback1
D       10.3.2.0 [90/2297856] via 172.16.124.3, 00:08:37, Serial0/0.1
D       10.2.3.0 [90/2297856] via 172.16.124.2, 00:08:37, Serial0/0.1
HQ#
HQ#ping 172.16.124.2
Sending 5, 100-byte ICMP Echos to 172.16.124.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/42/108 ms
HQ#ping 172.16.124.3
Sending 5, 100-byte ICMP Echos to 172.16.124.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/30/72 ms
HQ#
East#show run
Current configuration : 1077 bytes
version 12.3
hostname East
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback1
ip address 10.2.1.1 255.255.255.0
interface Loopback2
ip address 10.2.2.1 255.255.255.0
interface Loopback3
ip address 10.2.3.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
ip address 172.16.124.2 255.255.255.248
frame-relay map ip 172.16.124.1 201 broadcast
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.2.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
no ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
East#show frame-relay map
Serial0/0.1 (up): ip 172.16.124.1 dlci 201(0xC9,0x3090), static,
              broadcast,
East#show ip interface brief
Serial0/0.1                172.16.124.2    YES NVRAM  up                    up
Loopback1                  10.2.1.1        YES NVRAM  up                    up
Loopback2                  10.2.2.1        YES NVRAM  up                    up
Loopback3                  10.2.3.1        YES NVRAM  up                    up
East#show ip route
D       10.3.1.0 [90/2809856] via 172.16.124.1, 00:12:16, Serial0/0.1
D       10.1.3.0 [90/2297856] via 172.16.124.1, 00:12:16, Serial0/0.1
C       10.2.1.0 is directly connected, Loopback1
D       10.1.2.0 [90/2297856] via 172.16.124.1, 00:12:16, Serial0/0.1
D       10.3.3.0 [90/2809856] via 172.16.124.1, 00:12:16, Serial0/0.1
C       10.2.2.0 is directly connected, Loopback2
D       10.1.1.0 [90/2297856] via 172.16.124.1, 00:12:16, Serial0/0.1
D       10.3.2.0 [90/2809856] via 172.16.124.1, 00:12:16, Serial0/0.1
C       10.2.3.0 is directly connected, Loopback3
East#ping 172.16.124.1
Sending 5, 100-byte ICMP Echos to 172.16.124.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/66/112 ms
East#ping 172.16.124.3
Success rate is 0 percent (0/5)
East#
West#show running-config
version 12.3
hostname West
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback1
ip address 10.3.1.1 255.255.255.0
interface Loopback2
ip address 10.3.2.1 255.255.255.0
interface Loopback3
ip address 10.3.3.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
ip address 172.16.124.3 255.255.255.248
frame-relay map ip 172.16.124.1 301 broadcast
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router eigrp 25
network 10.3.0.0 0.0.255.255
network 172.16.0.0
no auto-summary
no ip http server
ip classless
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
West#show frame-relay map
Serial0/0.1 (up): ip 172.16.124.1 dlci 301(0x12D,0x48D0), static,
              broadcast,
West#show ip interface brief
Serial0/0.1                172.16.124.3    YES NVRAM  up                    up
Loopback1                  10.3.1.1        YES NVRAM  up                    up
Loopback2                  10.3.2.1        YES NVRAM  up                    up
Loopback3                  10.3.3.1        YES NVRAM  up                    up
West#show ip route
C       10.3.1.0 is directly connected, Loopback1
D       10.1.3.0 [90/2297856] via 172.16.124.1, 00:17:02, Serial0/0.1
D       10.2.1.0 [90/2809856] via 172.16.124.1, 00:16:51, Serial0/0.1
D       10.1.2.0 [90/2297856] via 172.16.124.1, 00:17:02, Serial0/0.1
C       10.3.3.0 is directly connected, Loopback3
D       10.2.2.0 [90/2809856] via 172.16.124.1, 00:16:51, Serial0/0.1
D       10.1.1.0 [90/2297856] via 172.16.124.1, 00:17:02, Serial0/0.1
C       10.3.2.0 is directly connected, Loopback2
D       10.2.3.0 [90/2809856] via 172.16.124.1, 00:16:51, Serial0/0.1
West#ping 172.16.124.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/28/40 ms
West#ping 172.16.124.2
Why my East router cant ping West router and vice versa..???
Split-Horizon has been disabled.
Please reply back.
cadet alain
You have a Hub and spoke topology so you also need to put a frame-relay map statement for the other spoke on each spoke:
on EAST: frame-relay map ip 172.16.124.3 201 broadcast
on WEST: frame-relay map ip 172.16.124.2 301 broadcast
with these 2 your pings will work.
Regards.
Alain.
cadet alain
Regards.
Alain.
Thankyou... You are 100% right..
