08-06-2011 07:03 AM - edited 03-04-2019 01:12 PM
Hey guys, just wondering if someone could clarify something about Frame Relay for me? I have attached a video which will hopefully explain things.
thanks
Daryl
08-06-2011 07:36 AM
this is very basic Frame-rlay topology ( FR is like a big L2 transport technology uses p2p links in the SP FR switch to tranasprot customers traffic over thses logical links )
have read using the following links to understand it a bit more about it
http://www.cisco.com/en/US/netsol/ns813/networking_solutions_solution_segment_home.html
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml
http://www.myhome.org/pg/frame.htm
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_q_and_a_item09186a008009457a.shtml
if helpful Rate
08-06-2011 07:44 AM
Daryl
Had a quick look at the video and yes it seems to be correct. Basically when we talk about a frame-relay switch we are really just talking about a router that has a lot of serial interfaces. So you simply connect each router on the edge to the frame-relay router and then configure the frame-relay setup.
So i think you should be fine with what you have setup. Have a look at this link also which shows how to configure the actual frame-relay router itself -
http://www.thebryantadvantage.com/Frame%20Relay%20Switch.htm
Have fun
Jon
08-06-2011 07:50 AM
Thanks very much for the speedy responses. I'll have a look through the links and see what I can do.
thanks again
