12-24-2007 05:32 PM - edited 03-03-2019 08:02 PM
I try a lab test with one 3620 (2 serial ports) and two 2620 router. I try to config the 3620 as a frame-relay switch.
Router_A
interface Serial0/0
ip address 192.168.2.1 255.255.255.0
encapsulation frame-relay
frame-relay lmi-type cisco
Router_B
interface Serial0/0
ip address 192.168.2.2 255.255.255.0
Router_C
interface Serial0
no ip address
no ip mroute-cache
no fair-queue
clockrate 56000
frame-relay intf-type dce
frame-relay route 100 interface Serial1 200
interface Serial1
no ip address
no ip mroute-cache
clockrate 2000000
frame-relay route 200 interface Serial0 100
Ping test between router A and B failed.
in Router C, sh frame-relay PVC; sh frame-relay LMI and sh frame-relay route is OK. In router A and B sh frame-relay PVC and sh frame-relay LMI is OK but nothing in "sh frame-relay map". Run "debug frame-relay pa" and do ping again, the result is encapsulation fail in link 38 (BRIDGE)
What could be the problem? Thanks
12-24-2007 08:38 PM
Posible causes,from what I can see in config is that lmi type must match both ends..
also ensure you have enable frame relay switching in your framerelay-switch.. try checking this and post results.
Router_B
interface Serial0/0
frame-relay lmi-type cisco <-lacks this statement
Rgds
Jorge
12-25-2007 04:26 PM
Thanks for reply.
Both side LMI-type is Cisco and in switch I do have the framerelay-switch config.
I run "sh cdp nei" in router A and B, both of two routers can see each other.
But run "sh frame-relay map" in router A anbd B there is nothing.
"sh frame-relay lmi" and "sh fram-relay pvc" without any problem.
Somebody said need use "frame-relay map bridge" command. Any idea? thanks
12-25-2007 07:53 PM
hi,
i think u r missing "frame-relay switching" command in ur frame relay switch.
Try out the command in the global configuration mode on the frame relay switch.
12-25-2007 07:55 PM
don't need bridge statement, actually create IP-to-DLCI mappings for Ra and Rb to communicate and try.
Router_A
interface Serial0/0
frame-relay map ip 192.168.2.2 [dlci#] broadcast
Router_B
interface Serial0/0
frame-relay map ip 192.168.2.1 [dlci#] broadcast
12-25-2007 08:52 PM
Actually ArunKumar is correct, don't need to place IP-to-DCLI mappings in router a or router b as I pointed it out, so please check your frame switching command in frameswitch, your configuration as it is router-a should be able to ping router-b and vice versa, as well as from each router be able to see your maping with show frame-relay map.
Rgds
Jorge
12-29-2007 10:10 PM
Hi, I change the configuration like this:
Switch keep the same but in Router A:
encapluation frame-relay
framrelay iterface-dlci 100
Router B:
framrelay iterface-dlci 200
This time "sh frame-relay LMI" and "sh frame-relay pvc" is good but "sh frame-relay map" still get nothing.
Then i enable RIP in router A and B. The magic thing happen: I can find the map entry in both "sh frame-relay map" and I can ping each other!
So I do a test again. I disable IP routing in both router then reload them. It's lost the mapping again and can't ping. After I enable RIP everything is OK.
I think the dynamic mapping should be invorked by a traffic like RIP. But why PING and CDP not make the mapping working?
12-29-2007 10:57 PM
Glad you got it resolved, however, the frame-relay maping should have shown at either end router A&B without RIP routing being involed as well as be able to ping each other becuase both ends are on the same network and the freame-relay switch just forwards the L2 traffic., once you create another network in each router for example on the ethernet interfaces then routing will be needed.
Rgds
Jorge
12-30-2007 05:45 AM
to avoid all the strange issues with DLCI mapping, please use only point-to-point subinterfaces, one for each PVC.
The main interface is inherently point-to-multipoint and causes this type of confusion.
