Frequency Dependent Pilot Sequence support
dsoldat1975
does anybody know if Cisco C1000 Series support the FDPS (Frequency Dependent Pilot Sequence, G993.5 G.vectoring)?
pieterh
this datasheet mentions G992.5 en G993.2 not G993.5!   so I guess not (Cisco would include this)
but this wiki mentions VDSL2 vectoring together with G993.5 / G.vector,
so as VDSL2 Vectoring is supported I'm not sure…. It may indicate pre-standard
DSL interfaces
C1116 and C1117
● Dying gasp.
● ITU G.993.2 (VDSL2) and supported profiles: 8a, 8b, 8c, 8d, 12a, 12b, and 17a.
● VDSL2 Vectoring.
● ADSL Annex A and Annex B ITU G. 992.1 (ADSL), G.992.3 (ADSL2), and G.992.5 (ADSL2+).
● ADSL Annex M G.992.3 (ADSL2) and G.992.5 (ADSL2+).
C1112 and C1113
● G.FAST (spectrum up to 106MHz) Annex A, Annex B, Annex M and compatible with ADSL2/2+ and VDSL2.
● ITU G.993.2 (VDSL2) and supported profiles: 8a, 8b, 8c, 8d, 12a, 12b, 17a, and 35b.
● ITU G.9700/9701/997.2 G.FAST and supported profiles: 106a, and 106b.
C1118
● G.SHDSL.
1. Check if Vectoring is enabled
IOS router shows the training mode as G993.2 even though the line is trained with full vectoring and this documented with the below cosmetic Bug:
Bug Link: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw72999
Recommended way to check if Vectoring is enabled on a line is using the command below:
CPE# conf t
CPE(config)# service internal
CPE(config)#exit
CPE#test vdsl 0 modem exec adsl info --vectoring
The output of the command is :
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 11864 Kbps, Downstream rate = 44782 Kbps
Bearer: 0, Upstream rate = 10456 Kbps, Downstream rate = 41800 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Vectoring state: 1
Total error samples Ethernet pkts sent: 0
Total error samples Ethernet pkts discarded: 0
Total error samples statuses sent: 0
Total error samples statuses discarded: 0
Vectoring state: 1 >>>> Vectoring enabled
2. Regarding FDPS (Frequency Dependent Pilot Sequence) differentiates ITU standard G.993.5 733 Modulation of Pilot Sequence:
https://community.cisco.com/t5/routing/fdps-frequency-dependent-pilot-sequence-differentiates-itu/td-p/4169340
Tags:FDPSSRAvdslwan
