General question about iBGP between PE routers in an MPLS network.
**Hamid**
I am working in a ISP company, I read that between PE routers should be always ibgp neighborship but in the Global VRF I can not see any bgp neighborship between PE routers only I can see IS-IS routing protocol.
can anyone explane me why i can not see any ibgp neighborship between PE routers in Global VRF?
Hello @**Hamid**
glad to her it, just remember there are various show commands to see each specific bgp peering within their related address families
However the below command should show ALL bgp peering applied to the router.
sh bgp all summary
Kind Regards
Paul
12 Replies 12
Check below
MHM
I know this command, but there is not any output when I enter this command on a PE router
are you run any MPLS in PE ?
if Yes
then it can this router is P not PE
P dont have any ibgp with other router but it forwarding packet using GLobal routing + MPLS
MHM
Yes, LDP is running in PE routers , for example with ""show mpls ldp neighbor"" I can see many neighbors
check my edit to previous reply
MHM
I found out the BGP routers now. I can see them with ""show ip bgp vpnv4 all"" command
I do not know why I could not find them with show ip bgp summary  command
Hello @**Hamid** ,
>> show ip bgp summary
this is limited to AF iPv4 unicast  i.e GRT = Global Routing Table
show ip bgp vpnv4 all summary
this is a good command to check all L3 VPN related MP BGP sessions and stats about n. of rx prefixes in the rightmost column.
Actually in a modern ISP network there can be also a lot of L2 VPN services either using VPLS (many flavors here in more advanced options MP BGP is used for peer discovery and LDP for pseudowires setup or MP BGP can be used for both discovery and LSPs setup)  or EVPN with MP BGP control plane.
So even the second command may be not enough to get all the possible MP BGP sessions.
Hope to help
Giuseppe
Hope to help
Giuseppe
The answer
https://learningnetwork.cisco.com/s/question/0D53i00000Kt03eCAB/sho-bgp-vpnv4-unicast-all-summary
It seem you need to use vpn 4 unicast all in command to show mp-bgp neighbors
MHM
Hello
@**Hamid** wrote:
can anyone explane my why i can not see any ibgp neighborship between PE routers in Global VRF?
What do you see when you run this command?
sh bgp vpnv4 unicast all summary
Kind Regards
Paul
Hi Paul,
Yes with this command i can see the BGP routes. I used wrong command in the router
Hello @**Hamid**
sh bgp all summary
Kind Regards
Paul
