Getting Error: %CRYPTO-3-CONNID_ALLOC_FAIL: Crypto engine failed to alloca
ShaunieK226
Error That I am getting:
%CRYPTO-3-CONNID_ALLOC_FAIL: Crypto engine failed to allocate a connection ID for negotiation from XXX.XXX.XXX.XXX
Routers being Used: 2 Cisco 871
Software: 12.3(8)YI2 in one and Version 12.4(4)T7 in the other
Getting the message in router with 12.3(8)YI2 that is configured for 5 IPSEC Tunnels
In our 871 Cisco VPN router I am getting this above message. I have only 5 IPSEC Tunnels setup in this router.
This messaging started appearing only about 2 weeks ago in a router that has been functioning fine for over a year. I have one tunnel that consistently goes down, forcing me to reboot both routers in order to get the tunnel back up.
Any input would be appreciated. Thanks!
Shaun
paolo bevilacqua
Hi, please upgrade to something stable like 12.4(3j) and chances are it won't happen anymore.
