Gigabit Ethernet interface problem
bcobosm
Hi all,
I have the following router 7609.
------------------ show version ------------------
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 09-Dec-04 22:59 by pwade
Image text-base: 0x4002100C, data-base: 0x42318000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
Router uptime is 35 weeks, 4 days, 21 hours, 9 minutes
Time since router switched to active is 35 weeks, 4 days, 21 hours, 10 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System restarted at 15:05:20 DST Thu Oct 6 2005
System image file is "sup-bootflash:s72033-pk9sv-mz.122-18.SXD3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609 (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID FOX090900TQ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
8 Ethernet/IEEE 802.3 interface(s)
9 Virtual Ethernet/IEEE 802.3 interface(s)
74 Gigabit Ethernet/IEEE 802.3 interface(s)
8 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
and I issued
interface GigabitEthernet1/7
mtu 9216
no ip address
speed nonegotiate
interface GigabitEthernet1/8
dampening
mtu 9216
ip address X
no ip redirects
no ip unreachables
ip rip advertise 15
These interfaces don't get up
I have checked the fiber and it's good.
I have attached the "show interface" command
What could be the solution?
Thanks a lot in advance,
Beatriz
5 Replies 5
mahmoodmkl
Level 7
Level 7
HI
Have u connected something to it i mean any device or its a trunk port.Perfrom a no shut under u r interface.
Mahmood
Yes, I had performed a no shut under, but interfaces don't get up. Also, I have made loops but I doesn't work either..
Thanks a lot!
Beatriz
Are you sure that you use the correct optical cable - I mean single mode or multi mode. And double check the polarity (Rx, Tx).
Bye,
FCS
how come ur both the gigabit interface are having same MAC address. just check ur show int output and if possible it could be hardware address. log a call to cisco-tac get it replaced.
Hi all,
I want to thank you, your useful responses. The problem is solved. We have taken out module and inserted again and all ports are working properly.
Thanks a lot!!
Have a nice day :)
