GLOBAL VRF ROUTE LEAKING
slauzon
I am having issues with global vrf route leaking.It is working in an evironnement that has a dialer interface or a static route, but if the isp at the customer location use a dhcp connection, I can't redistribute the global route into the vrf.
Is there a workaround that we could use? We've already tried using two vrf, one on the inside network and one on the outside network but this give us some other issues that come with it and we would like to find another way.
rais
Level 7
Level 7
How about putting the interface itself in the static route?
Thanks.
rais
Level 7
Level 7
Thanks.
Thanks, it's working.
ip route vrf inside 0.0.0.0 0.0.0.0 fastethernet4 dhcp
