Graceful Restart
Rupesh Kashyap
Hi, What is the meaning of Graceful restart , how we can implement this in OSPF , BGP & Eigrp ?
crow930us
Level 3
Level 3
From a Network World article:
Using BGP graceful restart, the data-forwarding plane of a router can continue to process and forward packets even if the control plane - which is responsible for determining best paths - fails.
Graceful restart also reduces routing flaps, which stabilizes the network and reduces the consumption of control-plane resources.
http://www.networkworld.com/details/824.html?def
Cisco Documentation can be found here:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftbgpnsf.html#wp1041499
SunilKhanna
Graceful Restart (GR) is a way to rebuild forwarding information in routing protocols when the control plane has recovered from a failure.
EIGRP
router eigrp 100
eigrp nsf
OSPF
Router(config)# router ospf 4
Router(config-router)# nsf cisco/ietf
BGP
switch(config)# router bgp 65536
switch(config-router)# graceful-restart
Pls rate the post if it was helpful.
Regards, Sunil Khanna
