ā01-14-2017 09:26 PM - edited ā03-05-2019 07:50 AM
Hi All,
I want to build a setup with the following technology [GRE, L2TPv3 and Multicast]. Can you advise what Software IOS image I need to get for 2911 router; will c2900-universalk9-mz.SPA.152-4.M3 support all features of given technologies.
Also OSPF is considered for routing.
Imran
Solved! Go to Solution.
ā01-15-2017 04:00 AM
all four features you mentioned (GRE/L2TP/PIM Multicast/OSPF) are included in your image.
If you need to research features, it is best to use the Cisco Feature Navigator:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
ā01-16-2017 01:41 AM
Thank you mate.
ā01-19-2017 12:26 AM
ā01-21-2017 09:27 PM
Hi GPauwen,
Can u let me know how does it work., data package licensing shows right to use.
