GRE over IPSec performance issues
Spaniard141
I am troubleshooting a performance issue on a GRE over IPSEC tunnel between two sites.
After a lot of research, I ended up lowering the MTU size and configuring an mss value and this has reduced 99% of the fragmentation I was experiencing. The issue now is that the throughput is only a portion of the WAN link. Both sites are connected by a 100 Mbps metro e but when doing testing on it I can't seem to get any higher than 25-30 Mbps. I figured I would lose some due to the tunnel but not as much as I am.
See the configuration of the tunnel interface below:
Router 1
interface Tunnel0
bandwidth 100000
ip address X.X.X.X X.X.X.X
ip mtu 1400
ip tcp adjust-mss 1360
delay 1
keepalive 10 3
cdp enable
tunnel source GigabitEthernet0/0
tunnel destination X.X.X.X X.X.X.X
and the physical interface:
interface GigabitEthernet0/0
description BlahBlah
ip address interface GigabitEthernet0/0
duplex auto
speed auto
crypto map CM
Router 2
interface Tunnel0
bandwidth 100000
ip mtu 1400
delay 2970
keepalive 10 3
Physical interface:
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map CM
Also eigrp is being used
Any ideas as to how to address this problem?
2 Accepted Solutions
Hi Raul,
The very first thing that comes to mind is that the Gig interfaces have been set to auto negotiate the speed. Can you check what speeds have the interfaces negotiated to? If it is 1000 Mbps the line speed is more that the carrier contracted BW of 100 Mbps which means anything above 100 mbps sent over that will be discarded by the carrier. You can limit the interface capacity by hard coding the speed to 100 mbps which is the best option and if thats not possible try traffic shaping the BW down to 100 mbps.
Umesh Shetty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Actually Cisco documents a 2921's maximum IPSec performance at 207 Mbps and a 2951's maximum at 282 Mbps, so in theory either could push (but barely) 100 Mbps (duplex), but their recommendation bandwidths, still for IPSec, are 72 and 103 Mbps, respectively.  (Note: bandwidths are aggregates.)
In attachment, see tables 2 and 7.
10 Replies 10
Jeff Van Houten
Level 5
Level 5
2 questions. What model router? Have you tried a speed test or file transfer without the IPSec tunnel to see if you're truly getting 100Mbps on the link?
Jeff
The router models are 2951 and 2921.
I have not tested just GRE without IPSEC. I have been testing with an application called iperf which sends files between a server and a client and reports the file sizes and transfer rate.
Leo Laohoo
Hmmmm ... I'm suspecting you are using a 2900 router.
Can you please post the following commands:
1.  sh version; and
2.  sh crypto engine brief
Spaniard141
Leo
The hardware is
2951 on one end and 2921 on the other
Spaniard141
Leo
See below the Output of the requested commands.
R1#sh ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.3(2)T, RELE        ASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 28-Mar-13 13:17 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
R1 uptime is 26 weeks, 3 days, 21 hours, 1 minute
System returned to ROM by reload at 17:52:23 UTC Sat Apr 20 2013
System image file is "flash:c2951-universalk9-mz.SPA.153-2.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 487424K/36864K bytes of memory.
Processor board ID FTX1628AL00
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0       CISCO2951/K9         FTX1628AL00
Technology Package License Information for Module:'c2951'
Technology   Technology-package           Technology-package
             Current       Type           Next reboot
ipbase       ipbasek9     Permanent     ipbasek9
security     securityk9   Permanent     securityk9
uc           None         None           None
data         None         None           None
R1#sh crypto engine brief
       crypto engine name: Virtual Private Network (VPN) Module
       crypto engine type: hardware
                     State: Enabled
             Product Name: Onboard-VPN
               FW Version: 1
             Time running: 4294967 seconds
               Compression: Yes
                       DES: Yes
                     3 DES: Yes
                  AES CBC: Yes (128,192,256)
                 AES CNTR: No
     Maximum buffer length: 4096
         Maximum DH index: 0000
         Maximum SA index: 0000
       Maximum Flow index: 8000
     Maximum RSA key size: 0000
       crypto engine name: Cisco VPN Software Implementation
       crypto engine type: software
             serial number: 10EEF1A5
       crypto engine state: installed
     crypto engine in slot: N/A
RTR02#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 14:08 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
RTR02 uptime is 26 weeks, 5 days, 22 hours, 55 minutes
System restarted at 12:08:45 Eastern Thu Apr 18 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M2.bin"
Last reload reason: power-on
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FTX1711ALHK
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
License Info:
License UDI:
Device#   PID                   SN
*0       CISCO2921/K9         FTX1711ALHK
Technology Package License Information for Module:'c2900'
uc           None         None           None
data         None         None           None
RTR02#sh crypto engine brief
                     State: Enabled
               HW Version: 1.0
               Compression: Yes
                      DES: Yes
                     3 DES: Yes
                 AES CNTR: No
     Maximum buffer length: 0000
       Maximum Flow index: 3600
             serial number: 2172EDC3
Spaniard141
I keep seeing this in the logs:
Oct 22 19:52:44.250: %CERM-4-RX_BW_LIMIT: Maximum Rx Bandwidth limit of 85000 Kbps reached for Crypto functionality with securityk9 technology package license.
Could this be related? I have read that the SEC-K9 license limits encrypted throughput to less than or equal to 85-Mbps unidirectional traffic.
I just expected to see higher numbers than 30.
Hi Raul,
Umesh Shetty
Disclaimer
Posting
Yes, I would see that as an impediment.  It also would imply you're bursting above 85 Mbps.  More over, if going above this limit drop packets, and/or packets are being dropped if you're able to burst above your MetroE limits (as also noted by Umesh), either can be very adverse to TCP transfer performance.
Raul,
A 2900 router does not have the "oomph" to push 100 Mbps.
Disclaimer
Posting
