gre tunnelling issues
mirehteshamali
Hi all
we have  a  internet connection , but isp is using  a  GRE  tunnelling . They have adjusted the mtu  to 1492  and tcp adjust mss to 1452 . However  some websites are  not accessible , what could be reason , is  it  related to lower MTU  than 1500 ?
2)  as  tcp retransmites  dropped packets , we can concluded  that  is not related  to bandwidht restrictions , i  would apprecaite if some one from a Servcie provider background can give me a start to trouble shoot is issue
johnlloyd_13
Level 9
Level 9
hi,
is this an ISP managed router? did they apply these settings over the WAN interface?
kindly perform traceroutes to the unaccessible websites and post it here.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Standard GRE headers use 24 bytes (not just 8).  Try IP MTU 1476 and adjust-mss 1436.  Also, if not enabled, activate PMTUD across the tunnel.
PS:
PPoE is generally 8 bytes.  If you have a PPoE connection, decrement above by another 8 bytes.
