GRE VPN TUNNEL NOT FUNCTIONING
normanlee
Hello, I am working for my Case Study Requirement in School, and it is taking a while and the GRE Tunnel is still not working on my end. May I ask you to see what the problem is on my file? Thanks!
12 Replies 12
Share config here I can not open pkt
MHM
Here is the Topology, for the configuration, I am using the default configuration for GRE VPN Tunneling
ip add <add><mask>
tunnel source <int>
tunnel dest <int>
But, when I do that, site-to-site connections are still unavailable
what are the passwords for the routers ?
normanlee_2-1701728516586.pngnormanlee_3-1701728530276.pngnormanlee_4-1701728539085.pngnormanlee_5-1701728548277.pngnormanlee_6-1701728557789.png
Hello! Here are the passwords
the passwords in the file do not seem to work. Can you write down the passwords for:
SG-PLDT and MLN2-GLOBE
routers, as these are the tunnel endpoints ?
ISP Server Router
User Exec Mode
al0nz0
Privileged Exec Mode
1SPAdm1n
VTY
alonzo*1SP!
Central WAN Router
User Exec Mode
al0nz0
C3NTRALAdm1n
VTY
alonzo*C3ntral!
SG PLDT
User Exec Mode
al0nz0
SGPLDTAdm1n
VTY
alonzo*SGPLDT
MNL1 PLDT
User Exec Mode
al0nz0
MNL1PLDTAdm1n
VTY
alonzo*MNL1PLDT!
MNL1 GLOBE
User Exec Mode
al0nz0
MNL1GLOBEAdm1n
VTY
alonzo*MNL1Globe!
MNL2 GLOBE
User Exec Mode
al0nz0
MNL2GLOBEAdm1n
VTY
alonzo*MNL2Globe!
SG Router
User Exec Mode
al0nz0
SGAdm1n
VTY
alonzo*SG!
MNL1 Router
User Exec Mode
al0nz0
MNL1Adm1n
VTY
alonzo*MNL!
VTP
alonzo*2023
MNL2 Router
User Exec Mode
al0nz0
MNL2Adm1n
VTY
alonzo*MNL2!
VTP
alonzo*2023
Sure, here.
I cannot find the tunnels. Which routers are the tunnel endpoints ?
Also, the secret for the router below is not working:
MNL1GLOBEAdm1n
Better yet, just post the full configs of both tunnel endpoints....
normanlee_0-1701730832207.pngnormanlee_1-1701730852664.pngnormanlee_2-1701730869825.png
Hi, sorry here's the updated file, I have included your feedback. The VPN Tunnel should occur in SG router to Manila 1 and Manila 2 Router to Manila 1. My problem is that when I applied the GRE Tunnels, PCs from Manila 1 cannot ping PCs from SG/Manila 2. I hope you can fix this.
I also included an updated PKT file and screenshots of the configurations.
I assume with SG router you mean the one below ? Unfortunately the passwords do not work on that router either. I would suggest to add simple passwords like 'cisco' to the routers you want us to check.
SG Router
User Exec Mode
al0nz0
SGAdm1n
VTY
alonzo*SG!
Here, I have removed the passwords for the devices with Tunnel Configurations.
On Singapore Building (SG)
On Manila 1 Building (MNL 1)
On Manila 2 Building (MNL2)
Turn2
Do you have routes on each switch pointing to the IP network(s) at the far end via the tunnel interface?
