GRE with PBR
rana_beech
Could anyone give me a sample configuration for PBR and GRE. Today I only have 1 MPLS link and I want toback it up with a internet (IPSec GRE) link. I will be using one router only.
Arana
yes you can
Narayan
5 Replies 5
royalblues
Level 10
Level 10
You would not require PBR if both links are terminated on to the same router
Multiple routes with varying metrics should taker care of the routing
Narayan
Thanks Narayan. And if I need to use the back up also for Internet traffic (low priority) and the MPLS link for critical how do I go about it.
Arana
say u have a setup like R1 -- MPLS
Internet
access-list 100 permit tcp any any eq 80
route-map test permit 10
match ip address 100
set ip next-hop
interface
ip policy route-map test
Have multiple routes so that your MPLS traffic falls back over to internet during failure
ip route 0.0.0.0 0.0.0.0
ip route 0.0.0.0 0.0.0.0 100
Narayan
one more question.
set ip next-hop
Can I make the as the GRE tunner destination on the far end?
Arana
yes you can
Narayan
