Guest Network Proxy Redirect
KyleA
Hello all,
We currently have a set up for our Guest Network using ISE web auth that looks something like this:
AP -> Foreign WLC -> ISE Auth -> Anchor WLC (DMZ) -> Switch -> Router
Everything works fine, but users are able to access any website/URLs - which we would like filtered. We have wireless proxies to handle this functionality but having difficulties properly redirecting guest traffic to these proxies.
Is this handled at the switch level or the router level?
I was made aware of using WCCP to achieve this, but haven't had any luck with it. Is this the common way to handle this functionality? Right next the gateway on the anchor/dmz WLC for the guest-int is pointing to the switch.
Hi.
It may depends where your proxy is placed and how your proxy work but I would say the router should be the one to talk wccp with porxy. Another option is PBR.
