Hairpin IOS 15.x simply via snat entry ?
digi076
Hi all,
I've read a lot of discussions about Hairpin NAT for Cisco IOS router. Mostly about creating an NVI, PBR or split DNS.
On my Mikrotik home router I was facing this issue as well but it was easy to enable a Hairpin NAT solution, see
https://wiki.mikrotik.com/wiki/Hairpin_NAT
Basicly you create a SNAT entry next to de DNAT entry. I saw some discussion online (other forum) that somebody managed to do this on a Cisco router as well, but no examples were shown.
Is this possible on a Cisco IOS router? It seems way more simple than the other suggestions to create a Hairpin NAT rule.
Thanks !
Hello
Domain-less nat (NVI) should be able to accommodate this, As the nat order differs from domain based nat in that NVI nat performs two route lookups before and after nat translation, thus internal hosts should be able to reach their own internal web server via its local destination natted address.
Example:
int x/x
description wan
ip address 1.1.1.1 255.255.255.0
ip nat enable
int x/x
description Lan
ip nat enable
access-list 1 deny host 192.168.1.10
access-list permit 192.168.1.0 0.0.0.255
ip nat source static tcp 192.168.1.10 443 1.1.1.10 443
ip nat source list 1 interface (wan)
Kind Regards
Paul
Hello Paul,
Thanks for your reply. Ok, so it's not possible like the way I provided in post? I read that NVI puts strain on the cpu, it's a 887 series router. Is NVI still the recommended method in this case?
Hello
have a look at this previous post
https://community.cisco.com/t5/routing/nat-/td-p/2475807
Kind Regards
Paul
