Hardware Limitation for service policy in 2960
alison.hou
I created an input policy-map to mark application traffic. When I  applied it to a interface on 2960, I got the following message:
14w2d: %QOSMGR-4-HARDWARE_NOT_SUPPORTED: Hardware limitation has reached for policymap QOS-LAN
        Can you please tell me what I should check?  here is "show ver":
CAHSIQCQC-WS-C2960#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 04:33 by yenanh
Image text-base: 0x00003000, data-base: 0x00AA2F34
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
CAHSIQCQC-WS-C2960 uptime is 14 weeks, 2 days, 3 hours, 2 minutes
System image file is "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin"
cisco WS-C2960-24TT-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
Processor board ID FOC1042ZH96
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:19:E7:F3:0B:80
Motherboard assembly number     : 73-10390-03
--More--
14w2d: %SYS-5-CONFIG_I: Configured from console by vty0 (10Power supply part number        : 341-0097-02
Motherboard serial number       : FOC104241XT
Power supply serial number      : DCA103459MZ
Model revision number           : B0
Motherboard revision number     : C0
Model number                    : WS-C2960-24TT-L
System serial number            : FOC1042ZH96
Top Assembly Part Number        : 800-27221-02
Top Assembly Revision Number    : C0
Version ID                      : V02
CLEI Code Number                : COM3L00BRA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C2960-24TT-L    12.2(25)SEE2            C2960-LANBASE-M
acampbell
Here is the official statement re the error
Error Message    QOSMGR-4-HARDWARE_NOT_SUPPORTED: Hardware limitation has reached for
policymap [chars]
Explanation    This message means that the policy map configuration has exceeded the limitation of the hardware. You configured more QoS ACL entries than the number specified in the Switch Database Management (sdm) template. [chars] is the policy-map name.
Recommended Action    Reconfigure the class map or the policy map, and reduce the number of QoS ACLs.
Taken from link:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_11_ax/system/message/msg_desc.html#wp67245
You need to review your policy map
From the config guide
QoS ACL Guidelines
These are the guidelines with for configuring QoS with access control lists (ACLs):
If you use QoS ACLs for classification, you can use the sdm prefer qos global configuration command to set the Switch Database Management (SDM) feature to the QoS template. SDM configures system resources to support the maximum number of access control entries (ACEs). For more information on the SDM templates, see "Configuring SDM Templates."
It is not possible to match IP fragments against configured IP extended ACLs to enforce QoS. IP fragments are sent as best-effort. IP fragments are denoted by fields in the IP header.
Only one ACL per class map and only one match class-map configuration command per class map are supported. The ACL can have multiple ACEs, which match fields against the contents of the packet.
Regards, Alex. Please rate useful posts.
thanks. I will change SDM template to the QOS today.
