Have you ever had to implement jumbo frames WAN T1 connections?
curielg73
How would it work on TDM circuits? If I configure MTU 1700 on a T1 Serial interface, does the Access supplier also need to configure it or can I just configure it on my Cisco Routers only? I'm trying to understand if the Supplier is required to configure it also or not?  I also have Ethernet WAN connections and want to understand the same; does the Access Supplier need to configure their devices MTU or can it just be configured on the connecting CPE routers to work?
Rajesh SB
The MTU is required to be supported/configured  on the devices across the path .
Reagrds
Raj
Sandeep Sharma
MTU need to be similar end to end across the path.
Thanks & Regards
sandeep
