07-18-2006
07:26 PM
- last edited on
03-25-2019
03:13 PM
by
ciscomoderator
How can I check the health of 7200 router
i.e temperature,power supply status etc.
*I have min access on router......
07-18-2006 07:55 PM
'show environment all' should do it. You can do it from the user EXEC mode.
Paresh
PS. Pls do rate posts.
07-18-2006 09:01 PM
Hi Paresh,
Thanks for your reply.This command is working.
It is showing following output, as I am fresher
I am not able to conclude this output.
I am confuse!! It's good if you can explaine me.!
Power Supplies:
Power Supply 1 is Zytek AC Power Supply. Unit is on.
Power Supply 2 is Zytek AC Power Supply. Unit is on.
Temperature readings:
NPE Inlet measured at 28C/82F
NPE Outlet measured at 32C/89F
Voltage readings:
+3.45 V measured at +3.47 V
+5.15 V measured at +5.23 V
+12.15 V measured at +12.29 V
-11.95 V measured at -11.85 V
Thanks a lot.
Kunal
07-18-2006 09:07 PM
Kunal,
Basically, it's telling you that everything is okay:
- both power supplies are operational
- the temperature readings are quite normal
- the voltage readings are very close to what they should be.
Paresh
07-18-2006 11:36 PM
Thanks Paresh
Now its clear.
Kunal
