vipingupta4u
Beginner
hello friends, please help in the following topology. i am not able to ping 11.0.0.0 from 10.0.0.0 router. but i can see that route (11.0.0.0) in routers routing table???
please help me in following toplology!!!!
sky blue is configured as RIP (191.168.1.0/24 . 191.168.2.0/24 )
Bright yellow is configure with ospf area 0 as aa backbone area. ( 192.168.1.0/24, 192.168.2.0/24)
Dark yellow is configured with ospf area 1 (193.168.1.0/24, 193.168.2.0/24, )
last bottom left most is configured with eigrp 1 .(194.168.1.0, 194.168.2.0 , loopback 10.0.0.0 ,)
Redistribution ospf (area 0 process id 1)and rip (ver 2 , no auto-summary).
ABR:- s0/0/0 192.168.2.2/24 ospf area 0 process id 1
          s0/0/1. 191,168.1.1/24 rip ver 2
show run
interface Serial0/0/0
ip address 192.168.2.2 255.255.255.0
interface Serial0/0/1
ip address 191.168.1.1 255.255.255.0
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
redistribute rip subnets
network 192.168.2.0 0.0.0.255 area 0
router rip
version 2
redistribute ospf 1 metric 10
network 191.168.0.0
no auto-summary
Redistribution between eigrp and ospf
ASBR:- s0/0/0 193.168.2.2/24
          s0/0/1 194.168.1.1/24
ASBR:
Show run
ip address 193.168.2.2 255.255.255.0
ip address 194.168.1.1 255.255.255.0
clock rate 64000
interface Vlan1
no ip address
shutdown
router eigrp 1
redistribute ospf 1 metric 1544 10 255 1 1500
network 194.168.1.0
no auto-summary
router ospf 1
redistribute eigrp 1 metric 100 subnets
network 193.168.2.0 0.0.0.255 area 1
i am not able to ping 11.0.0.0(rip ) from 10.0.0.0 ( eigrp 1 )..but in the 10.0.0.0 router showing the routes of 11.0.0.0?
router 10.0.0.0
eigrp 1
BR#show ip route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, Loopback0
     11.0.0.0/24 is subnetted, 1 subnets
D EX    11.0.0.0 [170/2684416] via 194.168.2.1, 00:54:03, Serial0/0/0
     191.168.0.0/24 is subnetted, 2 subnets
D EX    191.168.1.0 [170/2684416] via 194.168.2.1, 00:37:32, Serial0/0/0
D EX    191.168.2.0 [170/2684416] via 194.168.2.1, 00:54:03, Serial0/0/0
D EX 192.168.1.0/24 [170/2684416] via 194.168.2.1, 00:54:03, Serial0/0/0
D EX 192.168.2.0/24 [170/2684416] via 194.168.2.1, 00:54:03, Serial0/0/0
D EX 193.168.1.0/24 [170/2684416] via 194.168.2.1, 00:54:13, Serial0/0/0
D EX 193.168.2.0/24 [170/2684416] via 194.168.2.1, 00:54:24, Serial0/0/0
D    194.168.1.0/24 [90/2681856] via 194.168.2.1, 00:54:24, Serial0/0/0
C    194.168.2.0/24 is directly connected, Serial0/0/0
BR#
BR#ping 11.0.0.0
Sending 5, 100-byte ICMP Echos to 11.0.0.0, timeout is 2 seconds:
Success rate is 0 percent (0/5)
BR#
6 REPLIES 6
Vinayaka Raman
Beginner
On R8 do show ip route 10.0.0.0 and you find no routes.
So please correct this..check the redistribution points.
basically your echo reply packet is not coming back as R8 does not have a route entry for 10.0.0.0
make a segment approach..
Regards Vinayak
ospf to rip redistribution at R2 is not happening..please check that
Regards Vinayak
hey vinayak... can you help me with redistribution?
running config of ASBR router.
router ospf 1
router rip
version 2
network 191.168.0.0
no auto-summary
.....i dont know where i am doing wrong please help me out !!!!
another ASBR ROuter
router eigrp 1
network 194.168.1.0
no auto-summary
router ospf 1
router rip
version 2
network 191.168.0.0
no auto-summary
try with metric 5
Regards Vinayak
there is no problem with the metric..i just readd the redistribute ospf to rip command and it is all working..
i was doing show ip rip database to check if the ospf to rip redistributed routes appear and they didnot
i just readd the redistribute with different metric 5 and it worked
then i tried with metric 10 and it worked..i think this is a problem with packet tracer..
now i can successfully ping 10.0.0.1 on R8
and can successfully ping 11.0.0.1 on R6
Regards Vinayak
thank you!!!!
