Im trying to upgrade my IOS. It wasnt at ROMMON before but I thought I can upload the IOS on the xmodem so i did a
en
conf t
config 0x0
reset / reload
Now that I am in the ROMMON. If i type CONFREG to change the BAUD, nothing shows up. Usually it gives options but this time, nothing.
>confreg
So I tried to go back to the normal CLI
>confreg 0x2102
>reset
What?
>reload
What?
I turned on the router manually and turn it back on hoping that it will work but it brought me back to rommon.
What should i do? Any ideas? Help!
