HELP HELP HELP !!!
Waqarahm3d
I have configured a NAT in my lab environment Static route and all configured can ping 4.2.2.2 from router after NAT can ping same DNS from local host as well. Did trace route worked perfect. NOW THE big issue is i can't access internet :S. i can't browse at all. please guys help me out.
And funny thing i have discoverd is my Skype is connecting but no one services seems to be working at all.
Tried flushing DNS as well
6 Accepted Solutions
Hey,
Did you try to configure helper-address or ip forward udp commands??
Alessio
ok on PC can you verify the hosts file is ok, if it is then do purge the dns cache: ipconfig/flushdns and try again, if still failing then disable dns cache service of windows and try again.
Post the results.
Regards.
Alain
Did you remove the following command yet, "ip route 0.0.0.0 0.0.0.0 FastEthernet0/0"
If your WAN interface is setup via DHCP then you do not need that command in there.  You use that command when there is a static IP configured on your WAN interface and even in that case your default route would not point to the WAN interface itself instead it will point to the next router.
Ok try setting up that DHCP setup on the router instead of the L3 switch.  Also you don't need that L3 switch in L3 mode so do you have the "ip default-gateway 172.168.10.1" on it?
No 3560 is fine you don't have to connect 2960.  Are you able to post the full config's minus the passwords from the router and the switch?
24 Replies 24
Waqarahm3d
Guys this is my first time in cisco forum if i have posted under wrong discussion portal please let me know . and also good directions are always helpful.
Cheers !!
paolo bevilacqua
You need to post config for others to see what is wrong.
This is one simple and sweet config i have on router Paolo (Thanks for reply).
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Serial0/3/1
no ip address
shutdown
clock rate 2000000
ip http server
no ip http secure-server
ip nat inside source list MSGHQ interface FastEthernet0/0 overload
ip access-list standard MSGHQ
permit 172.168.10.0 0.0.0.255
control-plane
banner motd ^CC
This L3 is used for Dissertation by Waqar, Please Log off Now !!
******************************************************************^C
line con 0
exec-timeout 5 0
password 7 00010B160854180F1924
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 5 0
logging synchronous
login
line vty 5
exec-timeout 5 0
logging synchronous
login
line vty 6 14
password 7 104B1109091801021A01
login
line vty 15
login
scheduler allocate 20000 1000
end
What is the ipconfig of your PC trying to access the internet?
Regards.
Alain
Regards.
Alain,
i have configured a DHCP on a L3 (Switch)..
Current configuration : 2611 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname MSGSwitch
no aaa new-model
system mtu routing 1500
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 172.168.10.1 172.168.10.10
ip dhcp excluded-address 172.168.10.250 172.168.10.254
ip dhcp pool MSGHQ
   network 172.168.10.0 255.255.255.0
   default-router 172.168.10.1
   domain-name MSGNorthampton.co.uk
   dns-server 4.2.2.2
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface GigabitEthernet0/2
interface Vlan1
ip address 172.168.10.10 255.255.255.0
ip classless
ip http server
control-plane
banner motd ^CC
line con 0
exec-timeout 5 0
logging synchronous
login
line vty 0 4
exec-timeout 5 0
logging synchronous
login
line vty 5
exec-timeout 5 0
logging synchronous
login
line vty 6 14
login
line vty 15
login
end
This is Switch Configuration,
C:\Users\Whitewizard>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Whitewizard-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : MSGNorthampton.co.uk
Ethernet adapter Bluetooth Network Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Netw
   Physical Address. . . . . . . . . : AC-72-89-F8-BD-B1
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Internet:
   Connection-specific DNS Suffix  . : MSGNorthampton.co.uk
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 08-2E-5F-80-9C-C3
   Link-local IPv6 Address . . . . . : fe80::5485:f22d:910b:7ee4%14(Preferr
   IPv4 Address. . . . . . . . . . . : 172.168.10.11(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 25 October 2012 14:49:08
   Lease Expires . . . . . . . . . . : 26 October 2012 14:49:08
   Default Gateway . . . . . . . . . : 172.168.10.1
   DHCP Server . . . . . . . . . . . : 172.168.10.10
   DHCPv6 IAID . . . . . . . . . . . : 554184287
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-5E-EB-F1-AC-72-89-F8-
   DNS Servers . . . . . . . . . . . : 4.2.2.2
   NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection:
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 1030
   Physical Address. . . . . . . . . : AC-72-89-F8-BD-AD
Ethernet adapter VMware Network Adapter VMnet1:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for
   Physical Address. . . . . . . . . : 00-50-56-C0-00-01
   DHCP Enabled. . . . . . . . . . . : No
   Link-local IPv6 Address . . . . . : fe80::41b4:a9e8:d7f9:f4e1%43(Preferr
   IPv4 Address. . . . . . . . . . . : 192.168.116.1(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 687886422
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
8
   Physical Address. . . . . . . . . : 00-50-56-C0-00-08
   Link-local IPv6 Address . . . . . : fe80::8591:8936:f51:b8e6%44(Preferre
   IPv4 Address. . . . . . . . . . . : 192.168.119.1(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 771772502
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Tunnel adapter isatap.{17EC9994-C3A9-47FA-85D4-F354C14C9D89}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.newton.northampton.ac.uk:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   IPv6 Address. . . . . . . . . . . : 2002:aca8:a0b::aca8:a0b(Preferred)
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{71139A12-C6A0-403D-81EA-DDDD6E746D6D}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{FF0B4719-983A-4F9A-9383-B602ACC88099}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter isatap.{AFEECE11-122C-446F-B193-4E15A61E2229}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
I suppose you can ping 8.8.8.8 from this PC ?
Can you also ping www.google.com from this PC ?
Regards.
Alain
Yes Alain ping to all open DNS works but it's not resolving names, I don't know if it's some sort of issue with DNS configuration which seems to be one but couldn't figure out where to troubleshoot it..
Hey,
Alessio
Post the results.
Regards.
Alain
Alain & Alessio,
Tried everything but didn't worked. I plug in 4 more pcs to same switch and guess what, on one of the pc everthing is working :S.
3 pcs including my laptop Emails and skype working but no browsing . i think i am giving up on this moving on to using another router and switch. I still don't know why this is happening it seem like i have a Gost Switch which only likes to work on pc of it's choice. lol.
Take this out from your router, "ip route 0.0.0.0 0.0.0.0 FastEthernet0/0".  And try again.
(by the way any specific reason you are using a non RFC 1918 IP Range?  Why not go with like 172.16.x.x or 192.168.x.x?)
@Alessio,
Connected 14 more pcs to the same switch and fresh configuration on new swtich and router it's all the same. out of 14 pcs only one is working rest of them are dead.
again ping +traceroute works can access local resources, when it comes to WAN link it's failing.
