Help me setup NAT
aleks222
Very simple network
client -> Cisco 881 -> ISP
 bit more details
 client(192.168.0.12) -> Vlan1(192.168.0.3, ip nat inside) -> Dialer0(90.157.26.245, ip nat outside) -> ISP
The configuration is enclosed at the bottom.
The problem is as follows:
Ping from the router is successfully transmitted through NAT
cisco.k259#ping 8.8.8.8 source 192.168.0.5
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/42/44 ms
cisco.k259#
Mar 13 16:57:56.436: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1657]
Mar 13 16:57:56.480: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.480: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1658]
Mar 13 16:57:56.524: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.524: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1659]
Mar 13 16:57:56.568: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.568: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1660]
Mar 13 16:57:56.612: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.612: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1661]
Mar 13 16:57:56.656: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
ping from the client does not go through NAT (no answer at all)
C:\>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 8.8.8.8:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
cisco.k259#
Mar 13 16:58:44.073: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8632]
Mar 13 16:58:48.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8633]
Mar 13 16:58:53.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8634]
Mar 13 16:58:58.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8635]
Can someone point out the cause of the problem and how to fix it?
 Running config
cisco.k259#show run
Building configuration...
Current configuration : 7255 bytes
! Last configuration change at 22:08:00 GMT Mon Mar 11 2019 by atest
! NVRAM config last updated at 14:43:41 GMT Sun Mar 10 2019 by atest
version 15.4
no service pad
service internal
hostname cisco.k259
boot-start-marker
boot-end-marker
logging discriminator FAN-FAIL severity drops 3 facility drops FAN mnemonics drops FAN_FAILED
logging buffered discriminator FAN-FAIL
no logging console
logging monitor discriminator FAN-FAIL
enable secret 5 $1$WSti$mDMsh6sXY2iguEI/Mchiy1
enable password xxxxxxxx_
no aaa new-model
memory-size iomem 10
clock timezone GMT 5 0
crypto pki trustpoint TP-self-signed-3690135629
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3690135629
revocation-check none
rsakeypair TP-self-signed-3690135629
crypto pki certificate chain TP-self-signed-3690135629
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
       quit
ip dhcp excluded-address 192.168.0.1 192.168.0.7
ip dhcp pool k259
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.3
domain-name k259
dns-server 192.168.0.12 8.8.8.8
lease 0 2
ip domain name k259
ip name-server 192.168.0.12
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
vpdn enable
vpdn-group PPTP_CLIENT
description Rostelecom ISP
request-dialin
protocol pptp
pool-member 1
initiate-to ip 10.0.0.1
cts logging verbose
license udi pid CISCO881W-GN-E-K9 sn FCZ164190LZ
username atest privilege 15 secret 4 6in4Lru2ZZ8N8cUij4q7JvPlkL..hsURCkjm.d4NOR2
no cdp run
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 10.0.47.132 255.255.255.0
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 10.10.11.1 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.0.3 255.255.255.0
ip address 192.168.0.5 255.255.255.0 secondary
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1360
interface Dialer0
description $ETH-WAN$
mtu 1436
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string 123
dialer persistent
dialer vpdn
ppp authentication ms-chap-v2 callin
ppp chap hostname 90.157.26.245
ppp chap password 0 XXXXXXXXXX
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
no ip ftp passive
ip dns server
ip nat translation max-entries all-host 400
ip nat inside source static tcp 192.168.0.12 3389 interface Dialer0 3389
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 3
ip route 10.0.0.1 255.255.255.255 10.0.47.1
ip route 10.10.11.0 255.255.255.0 wlan-ap0
dialer-list 1 protocol ip permit
snmp-server community k259 RO
access-list 1 remark internet
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.0.0 0.0.0.15
access-list 101 remark internet2
access-list 101 remark CCP_ACL Category=2
access-list 101 remark test 2
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 150 remark WAN rule
access-list 150 remark CCP_ACL Category=1
access-list 150 remark WAN rule entry
access-list 150 permit ip any any
vstack
banner exec ^C
% Password expiration warning.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
^C
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
privilege level 15
password xxxxxxxx
login local
transport input telnet ssh
ntp master
ntp update-calendar
ntp server ntp2.stratum2.ru
end
6 Replies 6
Dennis Mink
Are you able to connect to the internet and is it just icmp you are having a problem with. In which case put an access list on you dialer inbound allowing icmp echo replies.
Please remember to rate useful posts, by clicking on the stars below.
Could you give a more specific example of an access list? And where exactly to install it?
I am not well versed in Ios.
So, gentlemens, the problem was at CEF.
no ip cef
Brings NAT to the working state.
Hello
@aleks222 wrote:
Very simple network
 bit more details
cisco.k259#
C:\>ping 8.8.8.8
Request timed out.
Request timed out.
Request timed out.
Request timed out.
cisco.k259#
Looks like nat is working, Check to make sure you dont have any software FW on the client negating echo-reply, for testing tuning the client FW off and try again.
Kind Regards
Paul
There is no firewall on the client.
Through another router (not cisco) the client, without any configuration changes, successfully makes ping.
In the debug log you can clearly see that the ping request reached the router. But the answer is gone somewhere.
I am grateful for your advice, but do not assume that I do not understand anything in setting up the network.
I have problems not with the network, not with an understanding of the mechanisms of the network.
I have a problem with configuring the specific instance of the cisco router.
Therefore, instead of trivial advice, great benefit would be provided by tips or links to manuals "how to trace the packet path on the router and determine the reason for which it does not reach the destination."
