Help me to understand the work of NAT via PPTP
aleks222
I can not understand the work of NAT.
1. Cisco 881
2. PPTP tunnel to the internet provider.
3. NAT on the tunnel.
4. DNS queries pass through NAT successfully.
Mar 11 17:26:05.767: NAT: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [1331]
Mar 11 17:26:05.811: NAT: s=8.8.8.8, d=90.157.26.245->192.168.0.12 [2313]
5. All other requests (ping, RDP, http) do not pass through NAT. More precisely, NAT request conversion is present, but the answer is not present at all. As if there is no server response.
Mar 11 17:26:06.527: NAT*: s=192.168.0.12->90.157.26.245, d=213.189.197.94 [29678]
Mar 11 17:26:07.527: NAT*: s=192.168.0.12->90.157.26.245, d=213.189.197.94 [29679]
Mar 11 17:26:09.527: NAT*: s=192.168.0.12->90.157.26.245, d=213.189.197.94 [29680]
cisco.k259#ping 213.189.197.94 df-bit size 1436
Sending 5, 1436-byte ICMP Echos to 213.189.197.94, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/29/32 ms
Help me understand the essence of the error.
cisco.k259#show run
Building configuration...
Current configuration : 7255 bytes
! Last configuration change at 22:08:00 GMT Mon Mar 11 2019 by atest
! NVRAM config last updated at 14:43:41 GMT Sun Mar 10 2019 by atest
version 15.4
no service pad
service internal
hostname cisco.k259
boot-start-marker
boot-end-marker
logging discriminator FAN-FAIL severity drops 3 facility drops FAN mnemonics drops FAN_FAILED
logging buffered discriminator FAN-FAIL
no logging console
logging monitor discriminator FAN-FAIL
enable secret 5 $1$WSti$mDMsh6sXY2iguEI/Mchiy1
enable password xxxxxxxx_
no aaa new-model
memory-size iomem 10
clock timezone GMT 5 0
crypto pki trustpoint TP-self-signed-3690135629
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3690135629
 revocation-check none
 rsakeypair TP-self-signed-3690135629
crypto pki certificate chain TP-self-signed-3690135629
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
        quit
ip dhcp excluded-address 192.168.0.1 192.168.0.7
ip dhcp pool k259
 import all
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.3
 domain-name k259
 dns-server 192.168.0.12 8.8.8.8
 lease 0 2
ip domain name k259
ip name-server 192.168.0.12
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
vpdn enable
vpdn-group PPTP_CLIENT
 description Rostelecom ISP
 request-dialin
  protocol pptp
  pool-member 1
 initiate-to ip 10.0.0.1
cts logging verbose
license udi pid CISCO881W-GN-E-K9 sn FCZ164190LZ
username atest privilege 15 secret 4 6in4Lru2ZZ8N8cUij4q7JvPlkL..hsURCkjm.d4NOR2
no cdp run
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address 10.0.47.132 255.255.255.0
 duplex auto
 speed auto
interface wlan-ap0
 description Service module interface to manage the embedded AP
 ip address 10.10.11.1 255.255.255.0
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
 ip address 192.168.0.3 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1360
interface Dialer0
 description $ETH-WAN$
 mtu 1436
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer string 123
 dialer persistent
 dialer vpdn
 ppp authentication ms-chap-v2 callin
 ppp chap hostname 90.157.26.245
 ppp chap password 0 XXXXXXXXXX
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
no ip ftp passive
ip dns server
ip nat translation max-entries all-host 400
ip nat inside source static tcp 192.168.0.12 3389 interface Dialer0 3389
ip nat inside source list 101 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 3
ip route 10.0.0.1 255.255.255.255 10.0.47.1
ip route 10.10.11.0 255.255.255.0 wlan-ap0
dialer-list 1 protocol ip permit
snmp-server community k259 RO
access-list 1 remark internet
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.0.0 0.0.0.15
access-list 101 remark internet2
access-list 101 remark CCP_ACL Category=2
access-list 101 remark test 2
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 150 remark WAN rule
access-list 150 remark CCP_ACL Category=1
access-list 150 remark WAN rule entry
access-list 150 permit ip any any
 vstack
banner exec ^C
% Password expiration warning.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
^C
line con 0
 login local
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 access-class 23 in
 privilege level 15
 password xxxxxxxx
 login local
 transport input telnet ssh
ntp master
ntp update-calendar
ntp server ntp2.stratum2.ru
end
19 Replies 19
Hello
Have you made the changes suggested and what is the present status?
Kind Regards
Paul
No changes.
from router
cisco.k259#ping 8.8.8.8 source 192.168.0.5
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/42/44 ms
cisco.k259#
Mar 13 16:57:56.436: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1657]
Mar 13 16:57:56.480: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.480: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1658]
Mar 13 16:57:56.524: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.524: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1659]
Mar 13 16:57:56.568: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.568: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1660]
Mar 13 16:57:56.612: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
Mar 13 16:57:56.612: NAT: s=192.168.0.5->90.157.26.245, d=8.8.8.8 [1661]
Mar 13 16:57:56.656: NAT*: s=8.8.8.8, d=90.157.26.245->192.168.0.5 [0]
from client
C:\>ping 8.8.8.8
cisco.k259#
Mar 13 16:58:44.073: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8632]
Mar 13 16:58:48.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8633]
Mar 13 16:58:53.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8634]
Mar 13 16:58:58.706: NAT*: s=192.168.0.12->90.157.26.245, d=8.8.8.8 [8635]
Hello
so to summarise what is failing
Kind Regards
Paul
The main mystery remains: why do the DNS requests FROM CLIENT pass successfully through NAT, but the PING does not pass?
What is the difference between them?
aleks222
So, gentlemens,, the problem was at CEF.
no ip cef
Brings NAT to the working state.
