Help needed in sharing internet connection on MPLS network
Hi, we have our head office Cisco router configured with 12Mbps leased line and 12Mbps MPLS terminated onto same router. We have four branch offices connected through MPLS to head office and to each other. We want to share internet connection which is in our head office to branch offices. Can somebody please help in this configuration as we have basic Cisco knowledge. Below is our head office and one of branch office configuration. MPLS link is established and we can ping local LAN interface of each other.
Cameron Wheeler
Have you unplugged your router? Wait 10 seconds, then replug it in. Hope that helps :)
Using the local LAN interface with Cisco router configured at 12Mbps I was able to connect our network very efficiently. You should try a factory reboot of the software on the devices and then see if the issue is still occuring. This would be the best solution.
Cameron Wheeler
Yes, thank you. This worked!
