[help] problem sup720-3b ws-c6509-e rooter
hello all
i need help to see what is the problem of this router.
i have 2 ws-c6509-e whit each one your sup720-3b.
i have already bought a super engine compact flash that i am waiting to receive to try to put him up.
meanwhile i have formatted a compact flash in the  one that are working fine copy the ios from him.
i have put this compact flash on the dead one i try to boot the ios but i go always in ronmode
i have the log crash. someone whit the knowledge can tell what is wrong,
thanks a lot already for someone that can help me .
what is the configuration register on the RP ? It should be 0x2102.
What happens when you boot manually from ROMMON (with the boot command) ?
Thanks for The replys
i already try to boot from rommom
boot disk0:name of iOS file
or
boot system disk0: name iOS file
also try to boot from flash and wen the cpu rp  take control send break command and
put confreg 0x2142 so I don't try to upload startup config
he go like this
start download
Then crash and go again in rommom
another thing I see on log is
ssa_regyster.....  jtag unregonized
I want to see the entire boot-up process because the error messages are extremely valuable for troubleshooting.
Copy the same IOS file into this supervisor card (for the working one) and see if it helps.
Leo Laohoo
Unable to open show install running info file
The RP has failed.
Could be caused by many things, including hardware failure or has gone into ROMmon.
Active crashed three times, disabling auto-boot and dropping to rommon
And this here states that the RP of the supervisor card (slot 6) has unsuccessfully attempted to boot up.
I recommend you contact TAC and get the line card replaced.
