Hello.
I need some help to understand the output of show buffers command. At Big buffers and VeryBig buffers appear informations in "misses", "trims" and "created" like:
Big buffers:
14368763 hits, 631 misses, 348 trims, 348 created
66 failures (0 no memory)
VeryBig buffers:
592457 hits, 35 misses, 35 trims, 35 created
0 failures (0 no memory)
My router is a Cisco 1005. Does anyone help me to understand whether this informations above are troubles or not? I need to certificate the performance of the router...
Thanks for all.
