Help with CBAC
John Blakley
All,
I have the following scenario. I have an 871W router connected to the internet.
Public IP: x.x.x.x
private IP: 10.20.1.1
The wireless clients connect and pull a 10.20.1.x address from a local pool on the router.
Behind this, I have an ASA:
public ip: 10.20.1.2
private ip: 10.20.0.1
I have a host behind the ASA:
10.20.0.50
CBAC works great for the clients on wireless or hardwired into the 10.20.1.0 network, but it stops working for the hosts behind the ASA. I didn't see any traffic from these hosts or the 10.20.1.2 address under "sh ip inspect sessions" command.
Is there anything special that I need to do in this scenario?
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello John,
I suppose CBAC is enabled on 871.
just a basic check
what is the default gateway / next hop of default route on the ASA box ?
is the net 10.20.0.0/xx known on the 871 ?
there is a static route with next hop 10.20.1.2 on 871 ?
Have you got connectivity between 10.20.1.1 and 10.20.0.x with x=1 and x>1 ?
There are NAT rules on the 871 that include the 10.20.0.0 subnet ?
Hope to help
Giuseppe
