Help with REDBACK SmartEdge Router NAT configuration Please
Eric Boadu
Hello Team,
Has any one had experience with RedBack SmartEdge router and how do you configure NAT/PAT on it. I am having problem getting Nat/Pat work. My Cisco router NAT/PAT config is working great except RedBack and do not have much experience with RedBack. Please help with
Eric Boadu
Please help with step-by-step NAT configuration and how to apply the policy.
Eric
Eric
Enter this into Google -
"redback ip services and security configuration guide"
and then refer to the NAT chapter in the above guide.
Jon
Thank you Jon for the lead.
Eric
I tried this config on RedBack router and did not work any idea?
!Create the NAT pool
[local]Redback(config-ctx)#ip nat pool pool_dyn
[local]Redback(config-nat-pool)#address 11.11.11.0/24
[local]Redback(config-nat-pool)#exit
!Create the policy ACL
[local]Redback(config-ctx)#policy access-list NAT-ACL
[local]Redback(config-access-list)#seq 10 permit ip 10.10.10.0 0.0.0.255 class CLASS3
[local]Redback(config-access-list)#exit
Command Descriptions
ACL Configuration 8-13
!Create the NAT policy and apply the policy ACL
[local]Redback(config-ctx)#nat policy pol1
[local]Redback(config-nat-pool)#ignore
[local]Redback(config-nat-pool)#access-group NAT-ACL
[local]Redback(config-policy-acl)#class CLASS3
[local]Redback(config-policy-acl-class)#pool pool_dyn local
Eric
