Help with routing.
Ray
Hello everyone. I'm trying to get the routing correct on a cisco router that connects to a ubee cable modem. Basically, the cable modem has an internal ip of 192.168.0.1. The cisco routers wan interface is 192.168.0.250, and it's vlan's gateway  is 192.168.5.1. Machine's on the 192.168.5.x network can ping the 0.1 interface, but, they cannot get out to the internet. The route on the cisco router is a default 0.0.0.0 (which I think is all I need). On the UBEE Cable modem, there's no way to see the routes. Any ideas? I've not messed with routing in a very long time, and I know I'm missing something, but I'm under the gun to get this running, and I'm absolutely clueless. Any help and education is extremely appreciated.
6 Replies 6
Julio E. Moisa
Have you configured a NAT on the router?
Your config could be:
interface fa0/0
ip add 192.168.0.250 255.255.255.0
ip nat outside
no shut
interface fa0/1
ip add 192.168.5.1 255.255.255.0
ip nat inside
no shut
ip access-list standard PRIVATE-NETS
permit ip 192.168.5.0 0.0.0.255
ip nat inside source list  PRIVATE-NETS interface fa0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1 name INTERNET
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
nat is enabled on the 192.168.0.250 interface (Wan gigabit ethernet 0), it is also enabled on the ubee modem. Is that what you need?
Hi Ray,
Please compare my configuration with your, (the interface could be different but the essential is there)
Could you please share the config of the router?
Sorry Julio. Here is the config. I apolgize for my ignorance. I definitely appreciate your help.
yourname#sh conf
Using 2824 out of 262136 bytes
! Last configuration change at 19:18:49 UTC Mon May 29 2017 by admin
! NVRAM config last updated at 19:18:58 UTC Mon May 29 2017 by admin
version 15.1
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-3408197356
 enrollment selfsigned
yourname#sh conf
version 15.1
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
 subject-name cn=IOS-Self-Signed-Certificate-3408197356
 revocation-check none
 rsakeypair TP-self-signed-3408197356
crypto pki certificate chain TP-self-signed-3408197356
 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool POSPool
 import all
 network 192.168.5.0 255.255.255.0
 dns-server 209.18.47.62
ip cef
ip domain name yourdomain.com
ip name-server 209.18.47.62
ipv6 unicast-routing
ipv6 cef
license udi pid CISCO891-K9 sn FTX170480XF
username admin privilege 15 secret 4 MR2nmOG5zNvjnsoQEnC0ORGH9OJXUbCmvLXI8ckFRwY
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0
 ip address 192.168.0.250 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 ipv6 address autoconfig
 ipv6 enable
 ipv6 dhcp client pd prefix-from-provider
interface Vlan1
 description $ETH_LAN$
 ip address 192.168.5.1 255.255.255.0
 ip nat inside
 ip tcp adjust-mss 1452
interface Async1
 no ip address
 encapsulation slip
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface GigabitEthernet0 overload
ip access-list standard POSNET
no cdp run
control-plane
mgcp profile default
line con 0
 login local
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line aux 0
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
end
Hi Ray,
No worries, everything looks fine but the ACL 199 is missing, that is the reason that the computers are not getting Internet access, I suggest change it for a standard ACL
Current config:
Recommended config:
ip nat inside source list  PRIVATE-NETS interface G0/0 overload
About the DHCP scope, you should exclude the gateway.
ip dhcp excluded-address 192.168.5.1
 import all
 default-router 192.168.5.1
 dns-server 209.18.47.62  8.8.8.8  4.2.2.2
Remove ip default-gateway 192.168.0.1 from the configuration as its not required as you have already set the default route pointing towards 192.168.0.1.
ip default-gateway is generally used in those devices that do not support routing or in low end devices or used when you want to disable the routing feature ( no ip routing) from the router and make use of the ip default-gateway command
