Help with SFPs
whitbych1
I have a 3750 with 12 SFP ports doing routing at a remote property. I also have a backup T1 connection on a 2821 Router. I need to be able to connect the the gig ethernet RJ45 connection on my T1 Router to a port on my 3750 switch so I can do HSRP. I am trying to find a compatible SFP module to work. I couldn't find anything on Cisco's website. Does anyone have any suggestions?
I found these items on google but I want to ensure compatibility.
http://pc.pcconnection.com/1/1/89689-cisco-gigabit-ethernet-copper-sfp-transceiver-ds-sfp-ge-t.html
http://www.nulime.com/Cisco-10-100-1000Base-T-SFP-Transceiver-Module/p149822
Go for GLC-T SFP on the switch to connect to gig ethernet interface on the router.
GLC-T is supported on 3750 12 port switch model.
Have a look at the compatibility list -
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
-> Sushil
-> Sushil
Thank you this is the exact link I was looking for.
