hi
avinash.mangal
i hav problem to configure to upgrade 64kbps line to 128 kbps
spremkumar
Level 9
Level 9
Hi Avinash
Pls be clear on where exactly you are facing the problem ..
Are you facing this problem in modem config ?
or in router config ?
can you elaborate more on the same..
regds
