High CPU every 2 minutes 4500
Firuz Azimov
Had problem with CPU utilization in cisco 4500 (CATOS).
Every 2 minutes CPU utilization 60-70% for few seconds then decline to normal CPU utilization its about 15%.
show process cpu sorted showed that
K2AclCamMan Audit re process takes 60%.
What this process mean? How I can resolve it?
K2AclCamMan Manages the input and output TCAM hardware for QoS and security features
have a look on the below troubleshooting guides.
https://supportforums.cisco.com/document/133416/high-cpu-troubleshooting-cisco-4500-switch
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html
https://supportforums.cisco.com/discussion/10772656/k2aclcamman-audit-re-4500-cpu-peaks
regards,
-Do rate helpful posts.
