High cpu load when using l2tpv3
viktordavityan
We have couple l2tpv3 tunnels between C2911 and C1921.
which, in turn, pass through a DMVPN tunnel through the provider cloud.
And plain copy operation of a data, say ~100Mb and more in vlan 5 that  xconnected
lead to a high cpu load up to 100% on a C2911.
C2911 by itself DMVPN Hub Phase 1 with a 27 Spokes.
Both installed 15.4(3)M8
Is there something wrong with software hardware ore maybe misuse of technologies?
C2911
l2tp-class class71
authentication
password
pseudowire-class pw71
encapsulation l2tpv3
protocol l2tpv3 class71
ip local interface Loopback10
interface Loopback0
ip address 10.120.78.242 255.255.255.255
ip ospf 1 area 0
ip address 10.120.78.101 255.255.255.255
ip ospf 1 area 0
interface Tunnel0
ip address 10.120.37.15 255.255.255.0
ip mtu 1400
ip nhrp authentication cisco37
ip nhrp map multicast dynamic
ip nhrp network-id 37
ip nhrp holdtime 300
ip tcp adjust-mss 1360
tunnel source 10.120.0.198
tunnel mode gre multipoint
tunnel key 37
interface GigabitEthernet0/1.810
encapsulation dot1Q 810
ip address 10.120.0.198 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet0/2.5
encapsulation dot1Q 5
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 10.120.78.102 5 encapsulation l2tpv3 pw-class pw71
interface GigabitEthernet0/2.71
encapsulation dot1Q 71
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 10.120.78.102 71 encapsulation l2tpv3 pw-class pw71
C1921
l2tp-class class71
authentication
password <>
interface Loopback0
ip address 10.120.78.24 255.255.255.255
ip address 10.120.78.102 255.255.255.255
interface Tunnel0
ip address 10.120.37.24 255.255.255.0
no ip redirects
no ip proxy-arp
ip mtu 1400
ip nhrp map multicast 10.120.0.198
ip nhrp map 10.120.37.15 10.120.0.198
ip nhrp nhs 10.120.37.15
tunnel source 10.120.0.21
tunnel destination 10.120.0.198
tunnel key 37
interface GigabitEthernet0/0.627
encapsulation dot1Q 627
ip address 10.120.0.21 255.255.255.252
no ip redirects
no ip proxy-arp
interface GigabitEthernet0/1.5
no ip redirects
no ip proxy-arp
xconnect 10.120.78.101 5 encapsulation l2tpv3 pw-class pw71
interface GigabitEthernet0/1.71
no ip redirects
no ip proxy-arp
xconnect 10.120.78.101 71 encapsulation l2tpv3 pw-class pw71
PS. On C1921 sometimes there is an error occurs:
Jul 14 00:10:08.350: %SYS-2-MALLOCFAIL: Memory allocation of 18252 bytes failed from 0x2164AD18, alignment 128
Pool: I/O Free: 257984 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "IP Input", ipl= 0, pid= 165
-Traceback= 210115B8z 21648BA0z 21648818z 2164BE3Cz 211DC054z 211DC2C8z 211E2680z 211DA9CCz 211DAC58z 211DAD44z 211DAF90z 21032A48z 21032A2Cz
14 Replies 14
Julio E. Moisa
This messages: -Traceback= 210115B8z 21648BA0z 21648818z 2164BE3Cz 211DC054z 211DC2C8z 211E2680z 211DA9CCz 211DAC58z 211DAD44z 211DAF90z 21032A48z 21032A2Cz
The message above can indicate, lack of memory RAM or a Bug (you could require an upgrade)
Additional, I have tried to understand your topology but I think the L2TPv3 VPN is not passing through the DMVPN i see different used interface, is that right? also your config looks fine but you could simplify this line:
with
xconnect 10.120.78.102 5 pw-class pw71
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I think there is enough memory:
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 2B098420 333252732 66264692 266988040 48814064 232392796
I/O E000000 33554432 15208908 18345524 1824 3289676
L2TPv3 VPN is indeed passing through the DMVPN because there is no direct connectivity between hub and spokes . That's why we use tunnel in phase 1.
I feel that something like СoPP is needed here to limit the effect of GRE packets on the processor.
"Sh ip traffic" on both sides
C2911
IP statistics:
Rcvd: 282633437 total, 153748295 local destination
0 format errors, 0 checksum errors, 432540 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 128400822 reassembled, 1889 timeouts, 0 couldn't reassemble
169532725 fragmented, 339065647 fragments, 5369 couldn't fragment
0 invalid hole
Bcast: 318 received, 0 sent
Mcast: 12276195 received, 685470 sent
Sent: 13887060 generated, 1517220746 forwarded
Drop: 496780 encapsulation failed, 0 unresolved, 0 no adjacency
0 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
0 physical broadcast
Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 12 unreachable
110928 echo, 330 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
0 irdp solicitations, 0 irdp advertisements
4270 time exceeded, 0 info replies
Sent: 0 redirects, 5262 unreachable, 15 echo, 110928 echo reply
0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
0 info reply, 433052 time exceeded, 0 parameter problem
UDP statistics:
Rcvd: 283703 total, 0 checksum errors, 23 no port 0 finput
Sent: 286992 total, 0 forwarded broadcasts
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
TCP statistics:
Rcvd: 24163 total, 0 checksum errors, 7 no port
Sent: 22955 total
EIGRP-IPv4 statistics:
Rcvd: 12062837 total
Sent: 469003 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
OSPF statistics:
Last clearing of OSPF traffic counters never
Rcvd: 232540 total, 0 checksum errors
217488 hello, 9 database desc, 0 link state req
9083 link state updates, 5960 link state acks
Sent: 236661 total
217489 hello, 5 database desc, 3 link state req
12822 link state updates, 6342 link state acks
ARP statistics:
Rcvd: 221 requests, 65 replies, 0 reverse, 0 other
Sent: 207 requests, 233 replies (0 proxy), 0 reverse
Drop due to input queue full: 0
C1921
IP statistics:
Rcvd: 415055020 total, 208991994 local destination
0 format errors, 0 checksum errors, 42113 bad hop count
0 security failures, 0 bad options, 42 with options
0 stream ID, 0 strict source route, 42 alert, 0 cipso, 0 ump
0 other
Frags: 205068566 reassembled, 710266 timeouts, 0 couldn't reassemble
145753380 fragmented, 291506760 fragments, 170 couldn't fragment
0 invalid hole
Bcast: 454451 received, 892 sent
Mcast: 1130299 received, 1128979 sent
Sent: 3818279 generated, 3211695759 forwarded
Drop: 0 encapsulation failed, 0 unresolved, 0 no adjacency
2796 no route, 0 unicast RPF, 0 forced drop
0 options denied
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 897 unreachable
278531 echo, 18 echo reply, 0 mask requests, 0 mask replies, 0 quench
656 time exceeded, 0 info replies
Sent: 0 redirects, 12136 unreachable, 30 echo, 278531 echo reply
0 info reply, 5740 time exceeded, 0 parameter problem
UDP statistics:
Rcvd: 671543 total, 0 checksum errors, 43608 no port 0 finput
Sent: 210930 total, 417059 forwarded broadcasts
BGP statistics:
TCP statistics:
Rcvd: 115123 total, 0 checksum errors, 43 no port
Sent: 202651 total
Rcvd: 1131671 total
Sent: 1131370 total
Queue drops: 0
State-Refresh: 0/0
Queue drops: 0
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 3350086 requests, 4250 replies, 0 reverse, 0 other
Sent: 107088 requests, 723536 replies (0 proxy), 0 reverse
It's because of this
https://www.cisco.com/c/en/us/support/docs/dial-access/virtual-private-dialup-network-vpdn/24320-l2tp-mtu-tuning.html
you can try this....
C2911
xconnect 10.120.0.21 5 encapsulation l2tpv3 pw-class pw71
xconnect 10.120.0.21 71 encapsulation l2tpv3 pw-class pw71
c1921
xconnect 10.120.0.198 5 encapsulation l2tpv3 pw-class pw71
xconnect 10.120.0.198 71 encapsulation l2tpv3 pw-class pw71
And in https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_lserv/configuration/15-mt/wan-lserv-15-mt-book/wan-l2-tun-pro-v3.html
Cisco recommends
  • You must configure a loopback interface on the router for originating and terminating the L2TPv3 traffic. The loopback interface must have an IP address that is reachable from the remote PE device at the other end of an L2TPv3 control channel.
Nevertheless, your idea is clear and I tried to do as you suggested. But without any changes.
But about MTU and PMTUD...  thank you for advice. I somehow did not even value it. But still I don't go to significantly reduce the fragmentation.
Fragmentation processing often places quite an additional load on the processor.
What do you mean "without any changes"?
Is L2TPv3 still working?
You can ask your the provider to increase MTU on your interfaces...
More over your mGRE tunnels are not optimal...
You are using GRE without tunnel ptotection or IPSec
so the overhead is 24bytes + 4bytes tunnel key
so fot the tunnel you can have
ip mtu 1472
mss 1472-40
Yes it still working. And working fine with VoIP call, Internet surfing, mail ... but when  start to copy the file, a BIG file, in the same vlan, but from different sides of the tunnel problem is rising. I do not even able to get to the console, so the processor loads.
Tunnel already was set to 1400 mtu and 1360 mss.
What is behind the l2tpv3 tunnels? Any routers?
 Just switches with workstation connected from one side(C1921) . And cople of routers on the C2911 side (OSPF).
if you have routers on the C2911 side,
so you can try to use "ip tcp adjust-mss"
We move to the usual scheme without using the xconnect. And everything works as it should. Transmission of Big files and so on. Using xconnect on Low-end platforms is a masochism, pure evil. IMHO. Maybe I'm wrong. However, thank you all for your help.
   Some time has passed. I have additional equipment. And I decided to reproduce the problem at the lab.
The decision was quite prosaic, although it may be not so elegant - service policy hierarchy on both sides of l2tpv3 tunnel. CPU load did not exceed ~45% in the laboratory against almost 100% before.
Just a quick configuration examle from one side.
!Service policy definition
ip access-list extended FTP
permit tcp any any eq ftp
permit tcp any eq ftp-data any
permit tcp any eq ftp any
permit tcp any any eq ftp-data
ip access-list extended HTTP
permit tcp any any eq 443
permit tcp any any eq www
permit tcp any any eq 8080
permit tcp any any eq 3128
ip access-list extended SMB
permit tcp any any eq 445
permit tcp any eq 445 any
class-map match-all HTTP
match access-group name HTTP
class-map match-all FTP
match access-group name FTP
class-map match-all SMB
match access-group name SMB
policy-map INNER
class FTP
police 5000000
class HTTP
police 35000000
class SMB
police 25000000
class class-default
police 35000000
policy-map RESTRICT_POLICY
class class-default
police 100000000
service-policy INNER
! Apply to interface inbound
xconnect 1.1.1.1 5 encapsulation l2tpv3 pw-class PWC1
service-policy input RESTRICT_POLICY
