07-05-2014 06:09 PM - edited 03-04-2019 11:17 PM
Hi All,
I have Cisco 2851 router , having a problem with high cpu usage without having much of a traffic. Could some one help ??
show proc cpu sorted
CPU utilization for five seconds: 98%/95%; one minute: 98%; five minutes: 97%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 5407556 1913720 2825 2.79% 1.54% 1.21% 0 Load Meter
254 3011988 1177236 2558 0.63% 0.23% 0.05% 0 NIST rng proc
140 41117760 51656672 795 0.63% 0.86% 0.76% 0 IP Input
114 12794788 1203103573 10 0.47% 0.49% 0.53% 0 Ethernet Msec Ti
30 41812148 58190919 718 0.23% 0.24% 0.26% 0 ARP Input
375 40332 941 42860 0.15% 0.38% 0.23% 515 Virtual Exec
66 9648852 9570238 1008 0.15% 0.13% 0.13% 0 Per-Second Jobs
127 451920 1457546 310 0.07% 0.00% 0.00% 0 CDP Protocol
373 613484 9595699 63 0.07% 0.02% 0.00% 0 NTP
287 2452028 298701343 8 0.07% 0.09% 0.09% 0 MMON MENG
175 2060532 13467934 152 0.07% 0.11% 0.08% 0 CEF: IPv4 proces
17 136740 9338203 14 0.07% 0.00% 0.00% 0 IPC Periodic Tim
225 231152 18668237 12 0.07% 0.00% 0.00% 0 Inspect process
113 685012 57554715 11 0.07% 0.02% 0.02% 0 Ethernet Timer C
217 112900 9560008 11 0.07% 0.00% 0.00% 0 PfR BR Learn
136 3466068 296860369 11 0.07% 0.08% 0.09% 0 IPAM Manager
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
07-08-2014 10:04 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, appears to be mostly interrupt CPU. How much traffic isn't much?
Any thing "special" about the configuration?
07-08-2014 05:39 PM
Thanks Joseph,
Traffic is around 40 -60M . "special config. " I have created 8 traffic shapes on the inside and out side interfaces
07-09-2014 02:21 AM
Disclaimer
Posting
Is that aggregate, or in each direction?
07-09-2014 05:00 AM
It is aggregated traffic ..........
07-09-2014 07:22 AM
Disclaimer
Posting
If aggregate, then your CPU utilization seems high although can't say what the CPU impact is for 8 shapers.
07-15-2014 09:50 PM
Dear Joseph,
Thanks for the reply. I found out that Actually high cpu caused due to traffic usage occurred time to time. Problem was it's not captured on show interface summary ( even with load interval 30 )
07-16-2014 02:42 AM
Disclaimer
Posting
Ah, well that what normally drives high interrupt CPU, i.e. traffic forwarding, in your case, probably microbursts. Your shapers probably contribute to a higher CPU for that traffic than just the traffic forwarding needs.
Thanks for letting us know.
