High Latency on Eigrp
Mero Cisco
I have used a ospf as a routing protocol. When using ospf the ping response was 2-3 ms, now I changed the routing protocol to EIGRP, disabling the OSPF. Now the ping response is 20-25 ms. Why the latency grows up, I don't understand. The EIGRP is working fine but the network gets slow. Why this happen and what should I do to solve this. The static route also ping with 2-3 ms. While tracing the path is ok, the result is like static route.
Please help,
Mero
9 Replies 9
Raju Sekharan
A ping response is dependant on the latency on the links and the response time taken by the end hosts. A routing protocol doesn't have a role there
Can you share the ping and trace results while using ospf and eigrp
Raju
Dear Raju,
Please look at the following tracert command result
EIGRP
C:\Users\DELL>tracert 10.20.199.120
Tracing route to 10.20.199.120 over a maximum of 30 hops
  1    <1 ms     1 ms     1 ms  10.20.4.1
  2    <1 ms     1 ms     1 ms  10.20.0.4
  3    20 ms    21 ms    20 ms  10.20.142.199
  4    21 ms    22 ms    26 ms  10.20.199.120
Trace complete.
Static Routing
  3     4 ms     4 ms     3 ms  10.20.142.199
  4     4 ms     7 ms     5 ms  10.20.199.120
Trace complete.
- Mero
The dealy is happening between 2nd and 3rd hop
While running eigrp, can you login to 3rd hop and check if your return route is correct on that device
Also try a ping and trace from the 3rd hope back to your host and check the status
raju
Dear Raju,
1 is my network router
2 is main router
3 and 4 same router, 10.20.142.199 network connected to WAN interface and 10.20.199.1 connected to LAN.
No issue on the destination router, what may be the problem.
Mero
As mentioned earlier, the delay is heppening on your 2nd 3rd router
We need to troubleshoot further to narrow down the issue
Can you share the following outputs
1. From your host Trace to 10.20.142.199
2. From 1st router  trace to 10.20.142.199 and 10.20.199.120
3. From 2nd router trace to 10.20.142.199 and 10.20.199.120
4. From 3rd router trace back to your host connected on 1st router
Raju
A network diagram of your topology would be handy!
Also did you check your router's memory and cpu while running EIGRP is it higher when compared to static routes?
Is auto summary turned on in your eigrp configuration on the router? If so, turn it off.
Hardik Vaidh
Dear maro,
time responce is more between 2 & 3 hope. sp i have to check 2 and 3 hope.
can u share eigrp confi. check delpy also
send the second and third router configuration
do you have any default route or and gateway  on third and four
