Hmac Error on DMVPN Routers using ESP-SHA-HMAC
dganta
HI Team,
recieving the following errors in DMVPN with ESP-SHA512-HMAC, not sure why we are getting these errors though the traffic does not seem to be impacted. We are specifically recieving these error in DMVPN spokes
010240: *Jun 25 2017 21:57:54.645 UTC: %IOSXE-3-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00000864007532800199 %IPSEC-3-HMAC_ERROR: IPSec SA receives HMAC error, DP Handle 14, src_addr 10.1.1.1, dest_addr 10.2.2.2, SPI 0xbefe39f2
Please let me know what does the above error indicates and how do we get rid of these errors.
Dinesh
8 Replies 8
Philip D'Ath
I would move the platform onto a gold star release of code.  What model device is this, and what software version is it running at the moment?
Hi Philip,
This is 4300 and 4400 ISR G2 routers running the version 03.16.04b.S.155-3.S4b
Dinesh
Hi Philip,
Yes understand recommended to move to a gold release but is this kind of a bug which has been identified in the previous release as I need to be sure that the upgrade will fix the issue as these routers are in production.
Also I cannot figure out what these errors actually indicate. Are they harmless will it impact traffic.
Dinesh
This is the list of bug fixes.  The last one could be related to your issue.
Identifier
Description
CSCvb95663
NIM-2GE-CU-SFP: Cannot ping the GLBP Gateway IP.
CSCvb71936
Router may crash with "IOSXE-WATCHDOG: Process = HTTP CP" when running command show running-config with search option such as in below examples:
  • show running-config | include service-insertion swap src-ip
  • show running-config | section interface
CSCvc03634
Cisco 4300 ISRcrashes with following error message:
%PMAN-3-PROCFAIL: SIP2: pman.sh: The process bsm has failed (rc 139)
CSCvc08339
Cisco 4331 ISR with NIM-1MFT-T1/E1 and Frame-relay circuit does not come up.
CSCuz51603
Multicast crashed with an invalid leaf pointer.
CSCuz20847
Cisco 4000 ISR creates VLAN 1 interface on bootup.
CSCvc13910
Cisco 4400 ISR: password recovery mode is not getting properly cleared.
CSCvb70539
NIM-ES2 duplex mismatches after there is a change in speed auto.
CSCvb44279
Cisco 4451 ISR provides incorrect values for traffic in subinterfaces.
CSCva31303
Cisco 44xx ISR cannot send large, fragmented or reassembled packets into containers.
Thank you Philip for your replies. Will consider upgrading the image and see whether that makes any difference
Often it means that the affected traffic has been dumped.  If you are not noticing it then a TCP re-transmit is probably covering it up.
There are references to a bug when MD5 is being used.  Are you using MD5 (I hope not - it has not been a secure choice for some time)?
